Hey guys , my turn for a little help..LOL
1995 2wd,3.4,5 speed, 200k miles, no mods.
All was fine until a couple days back, while on the freeway it just starting running rough, I could hear it and feel it but it was still pulling fine and nothing unusual on the dash.
Got it home with some fancy foot work and having to use the emergency brake to keep my feet free since it felt like it would stall but it never did. Parked it and it started right up, idle is 300-800 rpm and the engine acts like it wants to leap out of the bay.
Threw a scanner on it, nothing, no codes and voltages are fine. Checked some live data and nothing odd, MAF gps is normal as well as all temps.
Double checked voltages with MM and temps with IR gun.
No contamination of any fluid.
Passed propane over the engine no visual or audible rpm change indicating a vacuum leak. Nothing odd concerning the exhaust visually or smell. It will start effortlessly even after being parked for 24 plus hours sitting outside. Idle is bouncing but what concerns me is the engine shake. I'm stumped without starting to pull things apart. Was gonna do a compression check but apparently a family member was in my tool box, and guess whats missing!
My gut says it's dropped a cyclinder but I'd expect some other symtom, smell rich, misfire or a scary knock.
Anyways I have an appointment for it on Monday with 2 Toyota Master Techs that went out on there own about 10 years ago so will let them have a couple hours of labor time to figure it out.
Thoughts?
Thoughts?
