You should measure what your voltage is like with the car on, and set it to whatever value is just below that. So if you are getting 12.2V with the car on, I would set it to 12.0. That is just to prevent it from draining the car battery. Most dashcams have an internal battery but it's ultimately up to how you want to set it up. If you want it always recording when you're away, then set it to 12 just so you're battery doesn't die. If your dash cam has a battery though, Just set it to whatever. I haven't ever seen a hardware kit that has both battery and accessory power lines.
