Difference between Hybrid and base front bumper 2011 Toyota Camry
3K views 3 replies 2 participants last post by  saturninin
I have a damaged front bumper on a 2011 Camry... I was able to get a fender off a 09 Hybrid so I'm good there (found out via this sight that they are different with headlights and bumpers).... but the question is what is the difference between a base and a hybrid other then the looks on the front bumper? Are they interchangeable minus where the fog lights mount (even though it's the same fog light) and what's up with the headlights as well? Any help would greatly be appreciated
Simple Question- Will a Stock bumper work on a hybrid if the same year
I think they should work if you replace the grille too. I think only the rear taillights are different, but should work if you replace the whole assembly. I don't see why it wouldn't fit.
