I replaced the backup lights as they were easy to get too.
Here is the link to the bulbs I used.
1. Take your plastic pry tool. and squeeze it between the panels where you see in the picture below. Work across the top near the window and pop that side out first, then just pull straight up to remove the cover.
2. Twist the bulb out, and pull. Then remove the oem bulb and insert the led. Some leds may need to be flipped depending on the polarity to work. Once you install both, verify they work before inserting it back by turning on your ignition (no engine) and putting it in R. Update: 04/06/2021 - first remove the wire plug from the bulb base, making the twisting of the bulb much more accessible (Thanks for the tip MGHiXSE)
Amazon.com: JDM ASTAR Super Bright Error Free 360-Degree Shine 921 912 GX-3020 Chipsets White LED Bulbs For Backup Reverse Lights: Automotive
Buy JDM ASTAR Super Bright Error Free 360-Degree Shine 921 912 GX-3020 Chipsets White LED Bulbs For Backup Reverse Lights: Back Up Lights - Amazon.com âś“ FREE DELIVERY possible on eligible purchases
www.amazon.com
