Do Michelin CrossClimate 2 tires reduce MPG?
68K views 61 replies 32 participants last post by  moymurfs
Hello! New member here. I am the owner of a 2020 HL Platinum Hybrid (Blizzard White/Caramel). The car has the factory Goodyear Eagle Touring tires. These tires seem noisy at highway speeds, and appear to cause the car to wander around (which makes me wonder if that is why LTA is all over the road). Anyway I actually have a set of Michelin CrossClimate tires in my shopping cart at Discount Tire. Then before I finalized the order, I read a few reviews that noted a 10 to 20% loss in MPG with these tires, particularly in hybrid cars (not just Toyotas). So, before I commit to a $1k spend, can anyone confirm the MPG loss, and are the CrossClimate tires worth the upgrade for the HH. Thank you!
Not sure this will help but when CR tested the CrossClimate+ - which the CrossClimate2 is based on - it rated rolling resistance as vey good which is one step below excellent in their five tier rating system.
Better still if you get some feedback from an actual user.
#31 ·
Not sure this will help but when CR tested the CrossClimate+ - which the CrossClimate2 is based on - it rated rolling resistance as vey good which is one step below excellent in their five tier rating system. Better still if you get some feedback from an actual user.
Crossclimate 2 s are rated “fair” in rolling resistance which is actually pretty bad on consumer reports rating system NOT “very good”. And yes I can attest that it dropped my fuel economy from roughly 32mpg to 29ish mpg in my ‘13 Camry. Didn’t know tires rolling resistance would make that much difference but it does.
Here's a very thorough thread about the CrossClimate2.
I just put a set of these on my 20” wheels of my Honda Passport Platinum. I have seen no reduction in fuel mileage and find the the quietest tire I’ve ever owned. My new Highlander will be in early August and I plan on replacing the factory rubber with a set of these. $980 post rebate at Discount Tire.
#9 ·
The wondering stopped for me on the highway without LCA. LCA still does it slightly though so I just don’t use it anymore. This is with my Michelin defender ltx that was a huge upgrade over the oem tires.
Keep in mind if you go to a discount tire they will buy your oem tires up to $100 each depending miles and condition if you buy tires from them. They will match their website too if you show them the price from it. Sometimes beating it.
Reactions: cb91710
#11 ·
I did order from Discount tire for install Tuesday. Got the $110 discount and a $90 veteran’s discount, but not any trade value mentioned. My car has ~5000 miles so the Goodyears probably aren’t worth much anyway. I traded in a 2020 RAV4 Limited Hybrid for the HH. The RAV had factory Michelins (Primacy?). That car tracked just fine and the LKA/LTA whatever worked perfectly. Jump ahead to the HH and a car that needs constant lane correction and useless LKA/LTA. Yes I did test drive the car, but on a very windy day. I noticed the wandering and attributed it to the wind. Outside of this, I do love the HH. Some folks say the lane keeping works fine in their car, and others are unhappy with it. I wonder what role tire brand might play in this If any.
#16 · (Edited)
I just drove cross country (CA to FL) with new CrossClimate2 tires.
Compared to my OEM Bridgestone tires (30K miles):
Smoother ride
No increase in noise and may be quieter (but I did not want to believe it)
Similar MPG
I make that drive several times a year and will say that figuring out MPG with the Highlander has been difficult. There is almost always wind of some sort on the route and the Highlander is a big and tall vehicle. That is why I say “similar MPG”. I check my indicated MPG every time I fill up but I don’t keep a log.
The smoother ride adds just a touch of vagueness to the steering. Mostly just a learning curve thing. I had no issues through the Tehachapi mountains.
Fantastic traction in the few rainstorms I drove through. No snow experience yet.
My tires are OEM spec. Avionics12 tires were wider because the OEM size was not available then.
#17 ·
Thank you for sharing your experience with the new tires. My #1 reason for getting away from the Goodyears is to hopefully improve on the car’s directional stability, without losing many MPG. Reading some posts, not necessarily Toyota, where some reported a 10-20% drop in MPG had me worried. #2 is reducing road noise. I guess I will find out tomorrow.
#20 ·
I have HyHy Plat, and have turned off Lane Tracing. Too much side- to-side squirm in the steering wheel going down a straight road. Add in the 2 troughs worn in the pavement by heavy trucks and the steering wheel shuffles from side to side as if a Poltergeist has grabbed the wheel. Also, since it is electric power steering, I figure turning off Lane Tracing reduces energy consumption and improves my fuel economy.
#21 ·
Here is an early report after 24 hours with the CC2 tires. I am happy with my purchase. My primary complaint with the factory tires (Goodyear) was directional stability. Now, the car actually wants to go straight ahead. I was actually surprised when I wanted to change lanes at 70 mph that it actually took some effort to get the car to change direction. I did not have Lane Tracing enabled, which is still useless. Maybe our lane striping here is just not good enough. Road noise is improved, like a more tolerable low hum at 70 MPH. Lastly, MPG, too early to tell but is promising. My overall MPG according to the meter was 33.9 when the CC2s were mounted. After about 35 miles of freeway and back roads I am at an even 34. If there any big changes or observations I will report back.
#23 ·
FWD, you still need to put on cables in a R2 chain control.
That's the beauty of having AWD... no need to kneel down and get your arms dirty to put cables on. Just need to carry them in the car, in case of R3 chain controls, like last December after christmas when the SB Mountains got hit with snow during the day (R2) and overnight, Big Bear Lake area called upgraded to R3 controls.
AWD and All-weather tires with sufficient depth, you shouldn't have issues, as beginning of last ski season my Nokian WR G4 SUV's were fine, and handled all the snow and ice without issues... then at the end of the season, the WR G4's were having issues due to being worn out for snow use
#25 ·
Yeah. I'm leaning towards a set of Goodyear WeatherReady. I have them on my van and they are fantastic in snow, but there was no mileage hit. Have 38K miles on them and they are holding at 6/32". Very good wear.
Like the Michelin CrossClimates, they are spendy.
With my deductable, I figure one accident would pay for 2 1/2 sets of either tire.
#28 ·
What was you OTD price with that deal? I am in need soon....figure after my last 20k dealer check-up, I will be due. Sitting at 16.5k miles now on our 2020. OEM Toyos or whatever they are are embarrassingly bad.
Sam's club doesn't currently have the Crossclimate2's in stock for my size and it didn't seem like ship to store was available. Hopefully they are available within the next month or 2.
If not, I'll put Nokians on or maybe Pirelli's....my MDX seems to really like the Pirelli Verde All season Plus's currently on it and they did great during ski/snow season here, again.
#32 ·
Just had the CrossClimate 2's put on last week. I can attest that yes, your mileage will go down. Hopefully it improves but I am not confident it will. We put about 150 miles on them this past weekend traveling back and forth for my son's dek hockey tourney. They do ride nice but, I need to let some air out. NTB aired them up too high, so my mileage will likely get worse. They are rocking at 44 psi cold right now. Door frame states 36 psi. I may split the difference and go with 40 psi all around and see how the ride changes with that.
Had to make a move: current OEM Toyos were at 4/5 32nds and wife was afraid driving in mod. to heavy rain. Traction control was on constantly and she could feel them hydroplaning. Only 17750 miles on the OEMs. Junk.
Cost for NTB as $939 OTD. Called 3 places and couldn't get them (Sam's, Costco and local indy tire shop), was quoted $1,113 OTD at Flynn's tire and called NTB and their price was $1,230 OTD. I asked about their price matching and they came down to $950 over the phone so I made the appt. At the appt., checked in and the store manager checked me in and said he could do even better and got me down to $939 OTD. Sam's, even if they had them, wouldn't be able to get that low.
I just hope after the initial wear in my mileage improves but for now, the ride and handling is much improved and winter handling will be far and above better than what we had previously.
#33 ·
Weight of the tire has a drastic affect on MPG. The heavier the tire, the more energy it takes to spin them up. Energy in a car = more torque or HP needed to get to speed. And you know what that means...more gas needed to do so.
#34 ·
The CC2's are not necessarily heavier. They are in line with the weights of the sizes for the orginal equipment tires
From tirerack:
TireWeight (lbs)
Bridgestone Alenza Sport A/S 235/65r1829
Bridgestone Alenza Sport A/S 235/55r2030
Toyo Open Country A43 235/65r1829
Goodyear Eagle Touring 235/55r2030
Michelin Premier LTX 235/65r1829
Michelin CrossClimate 2 235/65r1829
Michelin CrossClimate 2 235/55r20 (V-speed rated)29
Michelin CrossClimate 2 235/55r20 (H-speed rated)30
#35 ·
Even 1 pound per tire makes a HUGE difference...think centrifugal weight gain. If you lifted a 29 pound tire versus a 30 pound tire, you wouldn't be able to tell the difference. But your engine does when it's accelerating.
Here's a fun article to read and get all nerded out! FUN ARTICLE
#36 ·
If you look at the Tirerack data, CC2's aren't heavier than the factory equipped tires.
The V-rated CC2's are lighter than the factory tires for 235/55r20.
#39 ·
Maybe you're jumping to conclusions. If one had Falken Wildpeak AT Trail 235/65r18 on their car, then you would have a point, since they weigh in about 9 pounds more per tire.
Where are the weights for the CC2's in 18's? That is what I have.
Tirerack's website, under the "specs" link in the tire model page.
#40 ·
I had the dealer put on the V rated CC2's 18" before I picked the Highlander up. Can't compare fuel consumption to stock but I'm averaging around 21mpg mostly city driving. Not even at 1000 miles yet so may improve over time.
The CC2's ride really nice. My hopes are I can get away from having a dedicated winter tire and wheel setup and run the CC2 all year round.
#41 ·
In short no, but long is complicated. However to really reduce any loss in the MPG you need to make sure your tires are at their proper pressures, having the PSI lower or higher than the recommended rate set by Toyota can lead to bad fuel eccomony.
The Goodyear Eagle tires on my 2022 aren't as noisy as the 2020's.
