Does a long block motor from a 2000 Corolla fit in a base 1993?
1.5K views 7 replies 5 participants last post by  1jzdreamer
IM guessing I have a base because it has manual windows and locks.
Here is a picture of the 2000 Corolla motor:
money can do wonders....
but why don't you look for a more easy to swap engine??? A family are direct bolt on's IIRC
#8 · (Edited)
With a 2zz it may be a worth while endeavor, but I wouldn't consider that for a 1zz. A stock replacement motor is about 4-500, and you won't get anywhere with the 1zz for that much. Lots of fabrication and custom work needed to pull it off. The motor/trans may bolt over with the subframe, but exhaust would need work, shifter linkage perhaps, harnesses, lots of work.
