Does anyone know where to place the RTV when replacing the valve cover gaskets?
277 views 3 replies 3 participants last post by  Atreus21
2000 XLS.
So I'm replacing (again) the rear valve cover gasket after my first attempt failed. Oil started leaking pretty severely and I'm not sure exactly from where because I can't see. But my suspicion is I screwed up the application of the FIPG silicone.
As I understand it, it needs to cover those two seams on the driver's side:
It needs to cover the underside of the half-moon:
And you also need to have a bead at the corners where the cams engage with the timing belt:
Is that correct? If so, about how much should I use? Desperate not to screw this up a second time.
