Hello, I've had this strange issue where sometimes my power locks will lock, but not unlock. The only thing that fixes this 100% of the time is to turn the ignition over so that the battery is feeding power to it. Any idea what the issue might be?
Your link doesn't work. And so your saying it can't be the alarm? So could I get an old key fob and start using it? I have a 97 camry le. And which key fob would I need? Saw some on ebay for $30.if you have an led that is the valet switch, which is for the keyless and an alarm.
i think it is added with the alarm, but am not sure.
i have the valet sw. out as off. all doors locks work fine, manually by switch or automatically.
i did not notice your year, but here is a link for an older securikey system.
http://jjguy.com/securikey/securikeycommandmanual.pdf
it is mostly programming the remote, but you can change functions as well.
there is troubleshooting, but i have yet to figure out my programming problem yet.
in forums, worn or shorting wires is often referenced as the culprit.
