I know I was mis-informed about the law and this should help clear everything up. People constantly say that if your vehicle was manufactured with a DRL it must be used if you live in Ontario, so I was curious if this was true since I wanted to do the Disable DRL mod. Turns out it was almost true, until the Ministry turned down the proposed ammendment to Regulation 587. I will let you all read for yourselves the legislation regarding the matter and interpret the laws as you will. This is only to inform members of Ontario/Canadian regulations.
Highway Traffic Act of Ontario
Regulation: 587
Subsection: 10
Daytime Running Light Systems
10. (1) No person shall sell or offer for sale a daytime running light system that does not conform to the requirements of the Canadian Standards Association Standard CAN/CSA-D603-88, Daytime Running Light Systems. R.R.O. 1990, Reg. 587, s. 10 (1).
(2) For the purpose of subsection (1), a daytime running light system means a group of electrical components including the control unit designed for installation on a motor vehicle to automatically activate lights used to improve the conspicuity of the vehicle viewed from the front at all times other than when headlights are required. R.R.O. 1990, Reg. 587, s. 10 (2).
**Source** http://www.e-laws.gov.on.ca/html/regs/english/elaws_regs_900587_e.htm
Proposed Ammendment
Proposal Number: 10-MTO006
Effective Date: August 31, 2010
Decision: Rejected
Proposal
The Ministry of Transportation is seeking comments on a proposed amendment to Ontario Regulation 587 under the Highway Traffic Act.
This proposed amendment would require that daytime running lights (DRLs) must be used if the vehicle was manufactured with DRLs, or if DRLs were required to be installed during importation.
**Source** http://www.ontariocanada.com/registry/view.do?postingId=3462&language=en
This section defines the criteria for a DRL.
Highlights of this...
(44) Every passenger car, multi-purpose passenger vehicle, truck, bus and three-wheeled vehicle shall be equipped with two daytime running lamps or, if the daytime running lamps are optically combined with the upper beams of the headlamps, with two or four daytime running lamps.
(45) A daytime running lamp shall be white, yellow or white to yellow, in accordance with sections 3.1.3, 3.1.2 or 3.1.3.1, respectively, of SAE Standard J578, Color Specification (May 1988).
**Source**http://www.tc.gc.ca/eng/acts-regulations/regulations-crc-c1038-sch-iv-108.htm
Regulation: 587
Subsection: 10
Proposed Ammendment
Decision: Rejected
Proposal
