Hi,
I did it this time.....and I'm not normally a putz!!!!
1994 Camry V6, threw a code, I reset the light and noticed an intermittant miss at higher speeds. Decided to check the throttle body and I bought plugs since it was almost time. The throttle body was filthy, so I'm cleaning it and I had my neighbor crank the engine once to make sure the cyclinders didn't load up with fluid-As I started on the plugs I asked him if the ignition was off. Well, I'm installing the last plug when I hear a solenoid start clicking over by the battery or atleast on the driver side...sure enough he had left the ignition on and I was busy plugging and unplugging the coils and Map.
So, now the car starts and runs like a champ, 60-70mph no trouble, smooth idle...until it just dies. It will die idling, or driving and when it does and you try to restart, the check engine light does not light up, all the other lights work and it cranks. Cycle the key a bunch of times or wait awhile, or unplug the efi solenoid or ignition trigger and the light will come back on and the car will start and run fine...for few minutes. Sometimes when you turn the ignition on after it has died the check engine light comes on a second or two later-noticabley slow....
I've searched and googled and have not turned up much in this reguard, it's not the efi solenoid as I tried one out of my truck...
HELP..I'm guessing!!!
Doug
Doug
