2000 Camry LE, 4 cylinder 5S-FE engine (federal) with 182k miles just threw a check engine light, engine warmed up either when driving or at a stop light. The gas tank was and is 3/4 full.
My scanner found only these codes: P0440; P0441; and P0446.
I just checked the gas cap, which is on snug and clicks. It's a Stant brand, but there are no apparent problems visually. I think it held pressure, because when I removed it, I heard a gurgling sound in the filler neck.
Key on, engine off vapor pressure = .13 kPa, purge valve closed/off.
Engine off, EVAP VSV reads 34.0 Ohms (30-34 Ohms is normal at 68' F per Toyota's FSM). I tried blowing air into each of the vacuum ports, but no air flowed. So, is the VSV faulty?
What should I do next? Thanks
