Failed inspection - Catalytic Not ready O2 Not Ready
26K views 9 replies 6 participants last post by  SuperchargedMR2
I went to inspection a few days ago and got rejected, the guy asked if I changed the battery recently and I said yes back in October, he told me I have to complete a drive cycle, but since October it should of triggered by now? Well, I went to Gateway Toyota service center where I bought the car and showed him the inspection sheet and he too said its a drive cycle.
However, they gave no details on how I can activate it. Is anyone familiar on how I can get those 2 sensors to activate?
I found these details, but I am unsure how helpful it will be as its for 1998-2002 Toyota Cars:
Toyota: The HEGO monitor should run after idling the engine for nine minutes, then driving at a steady 25 mph for two minutes.
Toyota: The catalyst monitor will run after driving the vehicle at 40 to 55 mph for seven minutes, followed by driving at 35 to 45 mph for another seven minutes.
Hope you guys can help and thanks a ton
The mechanic that came over and I just drove in right after failing, basically said on day you go back, try running errands, go a decent distance, try to stay in for 10 minutes, go run another errand, try for 10 minutes and than head to inspection.
Based on what I found online, its nowhere near as simple as that, but I dunno how true it is. From what I have read from the older gen, I can imagine it applies to my gen as well? I also found this info as in general that I guess I will try, but its a bit more complicated.
The easiest and fastest way to complete the drive cycles and get the monitors ready that I have ever found is the following:
#1. Fully warm up the engine (idle about 9 minutes), then drive on the highway/interstate at normal interstate speed ( without stopping ) using cruise control for 15 to 20 minutes. This will test everything except for half of the evap system. Many of the tests can not be run at low engine speed or if you are accelerating with much throttle. This is why cruise control helps so much. It maintains a nominal engine speed, under load, at a constant speed while the engine is fully warmed up. This is the perfect condition that almost all tests will run at. If you don't have cruise control, just keep the throttle and speed as steady as you can manually.
#2. Park the car, turn it off and let it fully cool down for 1 to 1.5 hours ( depending on how hot it is outside ). This runs the other half of the evap test which only happens when the car is turned off and cooling down. It watches the pressure in the gas tank to see if it falls when it cools down. Some cars also have electric vacuum/pressure pumps the gets activated as the car is cooling down.
Perform these steps exactly two times.
Why twice?
There are 2 classes of OBDII codes, class A and class B.
Class A codes will set immediately or after only 1 drive cycle.
Class B codes will only set after being successfully tested on 2 drives cycles. Notice the word "successfully". If the proper conditions are not present during a drive cycle, the test won't run. This is why many people have to perform lots and lots of drive cycles to get the tests to complete. They simply don't know or understand how to create the conditions required for the tests to be successfully run.
Once you know how, it's very easy! Anyone can do it.?
I will try it out on my next day off from work and hope my odbII reader will have ready for the catalytic and o2
The best thing to do is to look into the rules and regulations for your country. I suggest this because your country might include safety related devices such as seat belt function tests, lighting, and air bags.
Testing here in America test for hydro carbons and NOx. It goes deeper when you start doing engine modifications to the emission equipment, then the validity of the vehicle is called into question.
The only time the safety equipment is called into question is after the vehicle has been totalled by the insurance company and the owner buys it back to rebuild it. In some places, that's called a Level 3 inspection. That's the only way it can be legally registered. Otherwise, it's just a parts car.
I used to do inspections. Completing drive cycles for some cars can be a PITA. In the future, you can get a memory saver that connects to your OBDII port and keeps the monitors from resetting. I think it's a cable that needs to be hooked up to a 12V battery. I've heard people talk about them, but never seen one in person.
#7 · (Edited)
Here's what I did to complete the drive cycle, maybe it will be useful for others. I did this recently, and I checked some guides on https://www.car.co.uk/media/guides/general/mot-checklist-and-guide before this and it was useful. So, first of all, the preparations. I made sure my tank is between 30 and 70 percent full, checked the alternator and the battery (these two must be strong and good quality), I let the car sit overnight in the garage with the keys out of the ignition and the door closed. After, I started my car and let it idle for three minutes in Park or Neutral, then turn on the headlights, the heater, and the rear heater for about five minutes. Then I put the car in gear and drove around at about 25 mph and after went up to 40 mph, and stoped. After I took it on a short freeway trip and repeated the las procedure I explained. After this, I got the car to the shop and re-checked everything again and it was ready. If I forgot to mention something, please correct me, but overall, that's what I did.
#9 ·
I've seen it done with driving 70mph, then drop to 55. But it takes more effort than just normal driving.
When I have emission testing, I will wait 2 weeks before I take it in. Though, AZ isn't CA and only tests the systems and verifies pressure on the gas cap.
No visual. Just verify the systems are complete and no CEL.
It makes me glad that I don't have to deal with any inspections or emissions testing where I live in WA State. Seeing what so many people have to deal with just to drive their car. Ugh....
