Hold it< hold it< hold it!!!!
HOLD IT EVERYBODY!!!!!!!!!!!
I wasent going to post a reply on this but after i saw brandon3155s post, i had to. Well about 2 weeks ago when i though everything was fixed IT WASENT!!!! After replacing the FPR, AFM, Temp sensor, fuel filter, checking for codes, replacing the coil, replacing the spark plugs back to factory spec ones, checking vacuum switches, checked distributor, checked idle speed, check EGR system, checked the cold start time switch and valve itself (ohm tested only) and lots more. I even went up to Toyota numerous time for advise, pretty much did everything you could possibly do to no avail. I was about ready to toss in the towel when i had an accident. While i was painting the frame of my truck i noticed a small amount of coolant dripping from the from differential. I finished what i was doing and followed the trail of coolant to a coolant return hose (the metal one that wraps behind the engine) that connects underneath the intake manifold and is held with two 10mm bolts. About 5 months prior to that, i replaced the head gasket so i was very familiar with what each part was for and where it went, i remember cleaning the metal pipe prior to installing the new gasket and second guessing myself on whether the gasket mating surface was clean enough, so to be sure i put this gasket sealer stuff on it to be sure it dosent leak. Well it started leaking. I figured this isent to bad, just drain some coolant, take out the bolts, replace the gasket. Nope i couldn't be that easy, when trying to take the bolts out, both bolts snapped off in the intake manifold, so now i had to pull the ENTIRE intake assembly to extract the bolts. (THIS IS WHERE IT GETS INTERESTING)!!!! I started to dissasembe the everything off the intake plenum when it got time to remove the cold start injector. When i pulled it out i noticed a drop of gas at the tip of if, dident think much of it. I got everything off and pulled the plenum off the runners. When i pulled it off what i saw shocked me, there was a puddle of gas in every on of the runners. I panicked, thinking it was all of my primary injectors leaking at once, then i tought to myself how common is it for all four injectors to fail at the same time? So i called a shop to get an opinion, it just so hapend that the guy i was talking to was an expert on the 22re and told me its very rare for all four to fail at once and that if i even had one injector fail it would be causing drivability issues (which i dident, only starting issues) he also added that the injectors on my engine are pretty reliable and he has never seen injectors on a 22re engine ever have to be replaced. He said its my cold start valve and that alot of 22re engines have this problem. He told me that the valve would get weak over time and start to leak constantly because even when you shut the engine off you still have 40psi of fuel pressure in the lines. That combined with a leaking valve = starting problems and flooding out. Finally i thought to myself, so i got the bolts extracted, put a new gasket in, put everything back together and my test drive was up to Autozone to pick up a cold start injector. In stalled it and to this day, my intermittent starting / flooding problems have not been back. Its weird but i think if i hadent have sheared those bolts off, i probably would have never found the starting issue. Its ashame i had to go through all that trouble but looking back on it now i like to think i fixed two problem at once. Brandon 3155, REPLACE THAT F!$#ING COLD START INJECTOR IF IT HASENT BEEN REPLACED BEFORE!!!!!!!!!!!!!!!
