FitcamX Dash cam installed on Platinum Trim
16K views 38 replies 21 participants last post by  2VZ-FE
For those in the market for a 4K dash cam, I recently made a video documenting my experience installing this in my Highlander. I've read reviews from other Platinum owners that the small case cover at the top did not fit with the additional wires from the digital rear view camera. I brang this concern to the seller and am happy to inform others that the company has since created a new cover that allows for extra clearance by snipping off a removable plastic piece along with an update that they have their own dedicated app now.
I will admit that initially finding space to cram the wiring harness was a pain in the *ss that took me 2 hours to figure out but I found a way to tuck them in to make it work. Let my pain be your gain!
I just found an interesting glitch in this product. Since it uses wifi to connect to your phone, if you are away from your home network, and try to use google assistant, it tries to connect via wifi which obviously doesn't work since the camera isn't in range to your home network and it apparently uses that before cell data. I had to turn off wifi to get any google assistant to work and then just turned the camera wifi off so that I wouldn't have to toggle it on/off when I come in the house. I don't access my camera now that it's set up and if a need arises I'll turn it on. I was going to check with the company to see if I did something wrong. BTW, I'm on Verizon on an Android device.
The Fitcamx app runs independently from the Toyota software so they never interact with each other. I don't think about it anymore other than glance at the blinking blue light to confirm its recording before I drive off. Once in a while when I'm waiting for my wife in the car, I'll access the app to test the videos and it's working perfectly. I wouldn't mind creating a video, was there anything specific you wanted to see in action?
#13 ·
Thank you for the video and write up. I was able to install the dash cam housing in less than 30 minutes using your instructions. I did add a bit to the housing myself with a mirror mount drilled into the housing for my Escort 360 Max. I also used a wire tap to connect the ground and power for the detector. I pushed the wire tap pins into the connector closest to the passenger side. This connector has only three wires coming from the aft end. White with black stripe is ground. The wire to the left of that one is switched power, so the detector turns on and off with the vehicle power. All wires tucked in without issues just like the video showed. Detector sits just below the mirror when fully installed.
#20 · (Edited by Moderator)
Only the front cam on this one.
mkay exactly how does that mount to the fitcamx?
I used a dremel to drill two holes just above the cam portion of the fitcamx…then screwed in the two long screws to mount it to the plastic housing…then used a cutting disc on the dremel to trim down the screws since there’s not a lot of clearance with the vehicle’s camera…
#22 ·
Thank you for the great video, @KambientRE ! It helped me with the installation.
Just wondering: did you notice any downsides when using a 128GB card?
Their website is ambiguous about this: “128GB(128GB Can Only View Video On The PC, And The Maximum Support For Mobile APP View Video Is 64GB)” - what does this even mean? That half the videos won’t be playable on mobile app when the card fills up? I tried the playback from mobile app and it seemed to be working fine, but the card was almost empty.
Thanks!
#23 ·
Thinkware claims to support only 128gb and recommends using only a Thinkware chip.
I'm running Samsung EVO 512s in both of our U1000s and they work just fine after formatting in the camera.
The documentation typically only lists support for products that they have actually tested.
#25 ·
Pretty expensive dashcam. Are they worth it?
Besides having a very "clean" install and final appearance, how do they compare to other dashcams on the market? I've found that dashcams only last a few years at most. So, I usually get cheap (but highly rated) dashcams for $50 or less since I've had to replace them every 2-3 yrs.
I usually just put them behind the driver sun visor near the top of the windshield next to my Fastrak tag. I usually have the sun visor down too. So, I almost never see the dash cam.
#26 ·
$500 deductible saved, no increase in insurance rates, AAA applied fault to the other party and agreed to process a total loss on my Corolla within 24 hours.
Ya... $1000 would be worth it.
The FitcamX is less than $200, not even close to "pretty expensive" as dashcams go.
My Thinkware U1000 was on sale for $400, normally goes for $500
Blackvue, which is another premium product is $400+
Anything under $150 is going to be useful, but won't do well at providing a license plate in the event of a hit and run.
Dashcams are not something you want to cheap out on.
#29 ·
I've been running this in my 2022 Camry since about Christmas. Install was pretty straight forward. I connected to it via wi-fi and ran a few initial tests. Seemed to work fine. Took a few pics downloaded a clip etc. Then I disconnected the wi-fi so I could use cellular to use a GPS app or access the internet. I reconnected recently to view some clips and see if the cam was functioning correctly. There are a few new clips on there, but about 95% of my drives are not recorded. I don't know what I'm doing wrong? Do I need to leave my phone always connected to it via wifi when I'm driving so that it records? That doesn't seem normal. I really don't want a camera that isn't consistent.
#33 ·
The Fitcamx only needs to be connected to an internet connection when you're attempting to view footage or download footage otherwise, 95% of the time, it's just recording on a continuous loop. If you're having issues with consistency, I'd try reformating the SD card from the app. Also try using a high endurance card rated for extreme cold/hot temps as the card can get hot. Another thing the instruction manual mentioned is using a card no higher than 64GB otherwise it can only be viewed from a computer. I've had no issues with mine so far.
#37 ·
Some cameras can do that.
The Thinkware U1000 has an optional radar module that "wakes" the camera when triggered. If there is no impact, the camera goes back to sleep without recording anything. If there is an impact (something as slight as opening a door), then it records the incident.
Without radar, you are limited to time-lapse, or record-on-impact, but the problem with that is it takes a second or two for the camera to wake up, so you may not actually record the impact if someone backs into your car.
#39 · (Edited)
Finally ordered one and installed it. But I ran the wires a little different and resorted to using a cable tie to assist me
the top cover, the center part broke off allowing me to finally to fit the cover and had to trim down the 2 legs to make install angle easier
so, you see some wiring from underneath
But it doesn’t bother me since you can’t see it unless you try to look
and here’s a driving video clip
