"Fly-By-Wire" Throttle Lag
38K views 52 replies 34 participants last post by  Broken!?
Has anyone figured out how to eliminate the throttle response lag for the "Fly-By-Wire" throttles for the V6s?
For everyone's information, I sent in a request to Toyota regarding the lag in the throttle response and got this a reply. I haven't tried it yet but thought I'd share it with everyone who wants to try it. Please, submit your results to this post if you do try this.
Here's what I got from Toyota:
The slight throttle lag you feel on your Tacoma is the engine computer
calculating throttle position for maximum performance and efficiency.
Currently Toyota does not have any TSB's out for the throttle lag. One
thing that may improve it some is to disconnect the battery for one
minute and drive the vehicle as you normally would for 50 miles. This
will pre program "learned" driving values into the computer and in some
instances improve the lag.
Are you refering to just throttle input lag or the lag before the truck hits it's powerband (3.5Kish).
I am not a fan of "fly by wire", Some MFG's are better than others...but it is the way of the future
The Tacoma is light years better than the Dakota's I had. I'd mash the pedal on those (02 and 06) and it was as though I was waiting for the hamster to get the wheel spinning faster before the trans would downshift to allow it to accelerate. They both had V8's too. Bordered on dangerous.
#12 · (Edited)
Funny you mention that....
I had a Dodge Ram that also had the throttle by wire. It had LAG also.....
I think all vehicles with this system have lag. With a 5.7L V8 and you step on the gas hard - you EXPECT TO GO SOMEWHERE immediately.... Some days it'd be good and other days (when you especially needed it), it'd lag big time. Besides that, you'd press the pedal down a good 1 inch or more and nothing would happen - then suddenly it'd kick in with what I would consider, too much gas. It wasn't sensitive enough.
The Dodge was nice that you could relearn/recalibrate (in the computer) the position (the *throw*) of the gas pedal. Technically - you'd just put the key into the ON position, step on the gas pedal to the floor and hold for 5 seconds and turn then back to OFF.
I used to play with the calibration and see what would happen. I'd only press the pedal halfway or less (giving it less *throw*). This made the pedal more sensitive as the throw was much shorter. It also helped with throttle lag. For towing and other long distance stuff - I'd always put it back to normal.
Makes me wonder if you can recalibrate the Toyota pedal or not??? I haven't seen or heard anything about it.....
Wonder if its worth a call to a dealer and talk to a master tech....
#11 ·
You know, I don't think I have ever noticed this. Come to think about it, I remember telling myself I though that vehicle was quick to respond when I need to pass or takign off from a red light. Than again it seems I can't help but love my Tacoma (or I did before it was stolen) so perhaps I am biased :)
#13 ·
I didn't really notice the lag ('07 2.7) until this thread popped up and I tried it. Sure enough, there is a slight lag. Can't say as it bothers me though. I've gotten used to the lag in all my vehicles (Ford, Honda, etc.). If I anticipate needing to get a good jump, I'll floor it a bit (1/2 second or so) early with my other foot firmly on the brake. Then get off the brake when it's time.
#14 ·
Jeez, I don't know what lag you're talking about! All of you have a manual tranny? Our Highlander has a big lag (and I remember my parents' '85 Camry had a lag which had nothing to do with drive-by-wire!), but my truck has no lag whatsoever.
Stomp on the gas (hard) and see how long it takes to respond.
I have an Auto. This winter with the colder air - it hasn't been as noticable. It's been pretty responsive. I kinda got used to it and it doesn't bother me. Unless of course, I NEED to step on the gas to move quickly in traffic...then, I notice it.
So perhaps the lag has to do with the computer compensating too slowly for certain conditions....Just guessing. Why else would the lag be less noticable in the winter ? Or my truck is just weird...:naughty:
#17 ·
For everyone's info:
I've tried what the dealer suggested and noticed a significant reduction in the lag time. It didn't eliminate it completely but it decreased the delay before the RPMs would start to increase.
My next project is to develop a way to install a mechanical throttle linkage to get instantaneous throttle response.
#21 ·
it sucks. i'm sure its more noticable to us manual guys. i've learned to blip it a hair in first, and from there, to lift of the gas a little sooner before clutch engagement
#24 · (Edited)
I'm glad there are other people experiencing throttle lag. I mentioned it a while back and people replied like I was crazy.
In my truck at least, there is a distinct lag between flooring the pedal and when the truck takes off. This is with the tranny in D. It's pretty annoying when you're trying to pass on the freeway. I've found the best thing to do is drop it out of D and into 4th gear.
#33 ·
Your 100% right on that one. The lag we are feeeling, IMO, is the time it takes the trans (in an automatic) to downshift gears. When in "D", most likely the torque convertor is "locked up", as it should be. By placing the trans in 4th, the touque convertor is no longer locked and thus the trans can downshift faster. It takes an extra fraction of a second to a second to unlock the torque convertor first, then to downshift to a lower gear. That little extra time can seem like an eternity when you need to move NOW.
#26 ·
Since I have found "D" finally on the new truck I have noticed there is even more delay in throttle lag than running in 4th. I didn't notice much lag at all until I found "D". I swear it feels like the truck does a different shift pattern to get to "D" as fast as it possibly can whereas in 4th it just shifted at optimum RPM's, not necessarily for fuel economy but power. Might just be me but it sure feels like a fuel economy minded vehicle since I have found "D" compared to just running all the time in 4th.
#32 ·
Toyota's electronic throttle stinks on ice. We used to crack up in the shop with the Siennas because you could snap the throttle and the idle wouldn't change a bit. I have a bimmer, and I'd swear there is a throttle cable in it, so responsive electronic throttle systems are possible. I also work on F-16s, and have never heard of a pilot complain of a slow response from side stick actuation. :lol: So, buy a BMW or a Lockheed Martin product.
