Foglights?
1.3K views 5 replies 4 participants last post by  TRXR4KDS
hello everyone i was looking at pics on car domain and i saw some red matrixes with yellow foglights and they are hotness. so i was gonna try to change my fogs to yellow but how can i? can i just change the bulb or look for some kind of cover? thanks in advance
TRXR4KDS said:
You could do either that you mentioned. There are yellow overlays (yellow stickers that go on the glass and also helps protect from stone chips/cracks) or get yellow bulbs. You can also get higher output bulbs or do the high beam bulb mod.
So youre saying one can just change the bulbs and put in higher wattage bulbs. I havent pulled mine out yet, since they both are working properly. However, I was considering putting in higher watt bulbs, but was concerned about the higher amp draw. :confused:
Using higher wattage bulbs is asking for trouble. You'll end up frying the wiring harness.
The safer way to increase the light output is doing what many other have done, 9005 (high beam bulb) to fit 9006 (low beam) conversion.
See link for more info: http://www.toyotanation.com/forum/t64369.html
