Well, I had the front license plate bracket installed today and Toyota did not let me down.....NOT! The person installing the bracket positioned the form fitting bracket so that there was a 2" gap between the bumper and the brackets bottom! It was such a sad sight. Seeing this debacle shocked me so much that I did not get upset and I did not go back into the service department. I simply got in my Venza, went home and uninstalled the assembly. Taking matters into my own hands. Regardless of how bad the install my drab Texas handicap license plate would stlll looke terrible in the bracket so I decided to dress up the assembly.
Additional Products Purcahsed
- A trip to Pep boys provided me with a ultra slim frame which fit within the bracket to solve the looks problem. I also purchase a second ultra slim frame for the rear license plate.
- Next, I stopped by my local Ace Hardware store and purchased a roll of 1/2" x 3/4" automotive/marine grade high density foam stripping with adhesive tape on one side and a role of heavy duty exterior mounting tape (equivalent to 3M's trim mounting tape).
Sub-Assembly
- The license plate was thoroughly cleaned then waxed.
- I attached the license plate to the bracket using the double sided mounting tape to ensure a well aligned and rattle free fit. (NOTE: The Toyota bracket is not of the highest quality. Both the top and bottom have about an 1/16" bow. Believe it or not this bow is noticeable especially if a bare license plate is mounted within the bracket.)
- The 1/2" x 3/4" high density foam stripping was attached to the open section on the bottom rear bottom of the bracket again using the double sided mounted tape leaving the stripping own adhesive tape available when mounting the bracket to the bumper. This step ensures the assembly will not rattle against the bumper plus ensuring a consistent gap between the assembly and the bumper.
Final Mounting
- The entire bumper license plate area was cleaned to provide unobstructed access to the bolt holes and a good surface for the stripping tape's adhesive.
- Removed the protective film from the foam stripping adhesive tape.
- Next I placed both Toyota supplied 6mm hex bolts into the assembly's mounting holes.
- While holding the assembly about an inch away from the bumper I screwed in both hex bolts just far enough to ensure the assemble was properly aligned.
- Using both hands I carefully and quickly pushed the assembly onto the bumper. With the back bottom stripping now adhered to the bumper the assembly was in place. The two hex bolts were tightened only enough to ensure the assembly was secure.
- Decorative covers were attached to the two top hex bolts and the two unused both mounting holes using the double sided mounting tape.
- Using the type of exterior mounting tape and exterior grade high density foam with its own adhesive tape ensures the entire assembly can be removed with little trouble and without damning the bumper's finish.
So there you have it. In spite of Toyota I grabbed victory from the jaws of defeat thanks to self control and a little imagination. In closing, I plan to add a photo to this reply within the new couple of days.
Oh, almost forgot. After completing the installation I contacted my Service Department Supervisor and explained the shoddy workmanship in a positive constructive manner. He assured me that both the service advisor and the tech would soon be counseled. Over the past year my dealer knows one thing for sure - "I am the customer who expects the job to be done correctly and is not hesitant to praise good work or if necessary point out less than acceptable products and services. I truly believe that if all automobile owners did this we might find ourselves with better dealers and service departments."
