Does your Solara have automatic climate control? (SLE models have the auto air) The servo that controls the 2 dampers that would relate to your issue is the AIR MODE servo which is above the climate control servo, both servo's are drivers side. If you remove the plastic panel below the steering wheel (panel with the hood release) Stick your head up there to the right of the steering wheel you'll see both servo's.
Run the car and adjust the controller for different settings and you should see the top servo moving when you switch modes, the bottom climate control servo will move when you move the temperature setting. In my experience these servo's are very quite, when you hear them move is when they're are about to crap out.
