Fuel Pump/Bracket Part Number Trouble Finding
1 reading
3.4K views 13 replies 7 participants last post by  ctvtodu
Good morning friends,
I have a 1985 22RE 4WD Xtra Cab DLX.
I found that my fuel pump has left the chat (see pic for a good laugh). The tank is atrocious as well and I'm just going go buy a new fuel gauge sending unit too because it was pretty nasty as well. I'm having a hell of a time finding all the right parts. I need:
1) Fuel Tank
2) Fuel Pump w/mounting bracket and gasket to attach to tank
3)Fuel gauge sending unit that also goes into the tank with seal.
Can anyone identify which is the right parts my for my year and it being EFI, 4WD Xtra Cab DLX?
Any of these fit?
You have not looked too hard Rockauto.com has your fuel tank for about $150. NAPA prob. has them as well they used to stock a lot of exhaust and tanks.
"Fuel Tank Tube Assembly, Suction" I think is what they call the part the fuel pump hooks too.
You will likely need to look at 4Runner parts 1985, 1986, 1987 etc....You might need to make something fit.Look in aftermarket just know it was called a "Hilux". I know they still make them and are on market even if Toyota discontinued it.
#14 ·
I'd run a couple of tanks with added fuel system cleaners through to make sure the lines, pressure valve, and injectors are clean now too. I've used them all- Techron, STP Ultra, B-12, Lucas, Seafoam. Pick one. They will over time clean out the parts. Kept my OEM system running great with only changing fuel filters and a one time replacement fuel pump. Idles smoother than a 22RE should.
