I think it's coming from the front somewhere. Noise is only heard while the car is moving. If I have the truck in gear, but stopped, you cannot hear the noise. If you are driving on a straight wide road, and turn the wheel to the right, the noise goes away while the wheel is turned to the right. As soon as the steering wheel comes back to centerline / straight ahead, the noise comes back. Turning the wheel sharply left the noise stays about the same, doesn't get louder.
Also, the left hub seems hotter than the right hub. Faulty left wheel bearing?
I've had bad bearings before, and each time I would feel some vibration coming through the steering column. But this time I do not feel any vibrations coming through the steering column.
Is this a bearing? CV axle? Other tests that I can do? Thanks in advance for your help
