Ok, so I was finally able to fix the P0420 code on my 2001 Corolla. From online searches this seems to be a common problem on 98-02 Gen 8th Corollas that reach 80,000 miles or more.
NOTE: Please beware that I am not a certified automotive technician and I do not recommend you do any of the steps written below. If you get a check engine light, you should take your car to an automotive shop with certified professional mechanics where they give you a warranty on any work done in your car. The log below is for information only and to help anyone who experiences a similar problem than mine. Read and do at your own risk.
Background:
I got my car used with 109K miles. After driving it for ~300 miles I got the famous P0420 code. No other codes present. Also, my car had a weird engine noise when going uphill at low speeds (20-40 mph). Sounded like pinging/knocking. I decided to let the car run through some fresh gas and injector cleaners before chasing this matter any further (solution to this was found and explained below)
So before taking that catalytic converter out and bolting a new one in, and since I had no idea how the previous owner(s) treated the car I decided to take the low hanging fruit approach to fix this issue. Besides, catalytic converter failure is usually a result of something else going wrong in the car (i.e. fuel system too rich/too lean, bad O2 sensors, vacuum leak, coolant leak into engine combustion, silicone poisoning, exhaust leak, etc). Therefore, I wanted to make sure that none of those conditions were there waiting to kill the new converter.
This is the list of things I did before replacing the cat:
- Cleaned MAF sensor with CRC Maf sensor cleaner (the sensor was filthy)
- Cleaned Air intake tube and box
- Replaced Air intake filter with Toyota OEM (old filter filthy as well)
- Replaced spark plugs with Toyota OEM iridium (old plugs very worn)
- Ran 2-3 tanks of gas with fuel injector cleaners (Chevron Techron)
After resetting the P0420 code it would come back between 200 to 300 miles
- Checked for intake vacuum leaks using carb cleaner/starting fluid method (found none)
- Checked short and long fuel trims with OBD2 scanner (working within spec)
- Checked for exhaust leaks with car parked and engine running (found none)
- Monitored coolant reservoir level to make sure It was not leaking into engine (coolant level never changed)
- Checked O2 sensors with OBD2 tool and seemed to work within specifications (O2 Sensor#1 would fluctuate rapidly between 0.1 to 0.9 volts and O2 Sensor#2 would fluctuate at slower rate between similar voltages). I compared the sensor plots to my Camry and their response seemed to be normal (i.e.no lazy sensors)
- Checked the O2 sensors heater elements with ohmmeter (working within spec)
- Removed O2 sensors for inspection and they looked structurally ok. Sprayed them with CRC QD electronic cleaner, which is supposed to leave no residue (Warning!!!: this may damage O2 sensors. I did it because I was planning to change the sensors if failure occurred).
P0420 re-appears more often between 80 to 100 miles
- I decided to remove the catalytic converter/resonator assembly for inspection. The catalytic converter inlet honeycomb substrate looked clean and in good shape. There was a thin layer of soot in the pipe not any different of that seen in the tail pipe of cars in perfect working condition. Also, I inspected the outlet side of the converter with a tiny mirror and light through the O2 sensor boss. It looked just like the inlet side. No carbon built-up or substrate damage.
- After bolting on the old catalytic converter assembly back to the car, I turn the engine on and to my surprise I hear an exhaust leak coming from the exhaust manifold at the engine bay. Upon closer inspection, I discovered that in fact there was a leak on the spring-loaded joint at the manifold-downpipe assembly. I take everything back apart, and removed O2 Sensor#1 and the bolts and springs that hold the downpipe. To my surprise, the spring-joint gasket was worn to the core. Since this spring-loaded joint is made to move as the engine rocks (acceleration/brake), it was causing an intermitent exhaust leak. This is why, when going uphill at 20-30 mph the automatic transmission downshifts, the engine would rock normally and the bad gasket would allow exhaust gases out producing a noise reminiscent of pinging/knocking. I bought a new gasket at Toyota dealer and assembled everything back together. Pinging/knocking/leak noise on uphill was gone for good.
P0420 now re-appers between 20-30 miles
- I connected my OBD2 scanner, warm up the car and set to record both O2 sensor#1 and O2 sensor#2. Once warm, I hold the throtle at ~2500 RPM for about 30 seconds to light off the cat. I checked the plots and O2 sensor#2 is mirroring the O2 sensor#1 voltage, which would mean that the catalytic converter is not doing 100% of its job. Therefore, I decided to look for a new catalytic converter.
I decided to search for a direct bolt-on replacement rather than cutting the old converter off and weld a new one in. The reason for this is so I could go back to the OEM converter assembly if the catalytic converter was not the real cause of P0420. I read that a bad ECM or an ECM needing a flash update are also causes of P0420.
My car is equipped with an OBD2 California emissions system (I live in Georgia). After doing some research, I discovered that these systems are supposed to be strict on catalytic converter performance and heard many horror stories on how nothing but an OEM catalytic converter would fix this code.
The Toyota OEM catalytic converter can be purchased for ~$1300. This is probably the best part available for the vehicle in the long-term. However, it was not an option for me due the short-term cost.
I searched Magnaflow's catalog for a direct-fit replacement. They have two options: PN 23881, and PN 46881. I called their tech support and asked them if any of those would work on my OBD2 Calif Corolla. The guy told me that PN 23881 (~$200 online retail) would not work. He said I had to get PN 46881 (~$400 online retail)
I called Eastern Catalytic tech support. I asked the guy if their direct-fit converter PN 40243 would work on an OBD2 Calif Corolla. He told me it will work. Since Eastern has 5 years and 50,000 mile warranty I decided to give them a try. Also, at ~$200 it was an economical option. (Keep in mind PN 40243 is 49-State legal, so it may not be legal in your State. Consult your State laws and the catalytic conveter manufacturer before purchasing)
- Replaced converter with the Eastern direct-fit converter. It came with a gasket for each end of the assembly. The pipes were mandrel bent and it looked of good quality. As opposed to the OEM system, the new system was split in two parts to be connected in the middle by an u-clamp. I assembled the two halves and compared length and orientation to old OEM assembly before installing back to the car. I got M8x1.25x30mm bolts and washers for the muffler end because the flange of new assy was thicker and the bolt-holes larger than stock. I had difficulty making the system leak tight at the middle u-clamp joint, I wish it had a better fit and/or leak tight connection with gasket. Also, be prepared to hear a subtle higher tone on your exhaust as compared to the OEM assy (due to different resonator/less restricted flow?)
It has been 1000 miles and no P0420 code, no Check Engine Light. Car passed Georgia emissions test with flying colors.
6/22/2011 Update: 10000 miles, running great and no P0420 code
