Have 2014 corolla s turbo need help !!
1.2K views 6 replies 3 participants last post by  bnsbaby2
I have a 2014 corolla s 6 speed
since new....
I have a turbo kit on it since 3 years ago
it has 100k
it sat 6 months all winter
I got the battery charged up it was dead
tried to start the car and It turns on but will not crank like the starter but I took the wire that feeds the solenoid 12v to start it and I jumped it 12v and the car turned over
now
im going crazy
I need help
key switch ??
maybe clutch switch
everything turns on it just will not crank the starter
any ideas would be great
I checked all my fuses under the hood im gonna get into it under neath the dash and check the fuses under the driver dash and im gonna unhook the clutch switch and jump it with a wire to see if its faulty
does anyone have any service bullitens on the no cranking......
Im hoping a mouse didn't get up there and destroy my wiring
PLS help!
You solved it here...
"...but I took the wire that feeds the solenoid 12v to start it and I jumped it 12v and the car turned over "
Whatever it was you bypassed has a fault in it... You may be onto something with mice chewing on wires as your main switch turns on everything.
Follow the small wires leading away from the start motor.
I should also note that yesterday I hot wired the starter and turned the key switch on hoping to see fuel pressure and maybe a start
did nothing
not a fire
it got 0 fuel pressure and I think its the ign switch
the dash light do not even turn on
I checked every fuse twice
does Toyota have any tech service bullitens that reefer to this?
I think the ecu isn't turning on
ecu main relay or starter relay?
how many of you have had to change the ign key swtich
today im gonna do some more volt meter testing
maybe take the plastic off the steering coloum to test
like I said any ideas are great ty
nope nothing
but ty
I am gonna go back out tomm and see
and when I jumped the wire on the starter the engine spun like normal and didn't fire
there has to be a wire that goes from my key ign switch that tunes the ecu on and off maybe its bad
I will check this somehow tom
ty again
im gtting desperate ty
the dash lights
the fuel pump and the starter wire go to the ecu and they all don't work
the ecu isn't powering up
tyyyyyyyyy
