Heat Shield?
1.7K views 9 replies 4 participants last post by  Bryan1
Question: Will I need a heat shield between the exhaust header and the radiator? The engine is a modified 20V Blacktop.
Any thoughts will be appreciated.
Thanks.
The stock 20V heat-shield pretty much just sits on top of the headers facing up, the part of the exhaust that is closest to the radiator (the lower part of the 4 primaries leading in to the collector flange) has no shielding (the 2 secondaries do though)
Was more just pointing out that the factory heat-shield doesn't really protect the radiator so unless you're mounting a turbo there I can't see an aftermarket setup being any worse
Understood. Thanks.
l think some thermal barrier between the header and the radiator make sense. Couldn't hurt. The aftermarket header seems a little closer to the radiator than the OEM setup.
I will not be adding a turbo.
Just looking for cool runnings. Build should be complete soon.
My 20v has an aftermarket header and I used to daily it in the SoCal 100+ heat. No issues
