Help 1998 t100 starter issues
1.6K views 5 replies 6 participants last post by  punk_and_goth
Hello.
So I reciently replaced the starter in my truck because the car would just click and not start. Now that the new starter is in it keeps doing the same thing. Is there anything else I can check? Is it possible the starter was put in wrong? Are there any parts I could try cleaning to make it start?
New part or Remanufactured? Sounds like a low voltage issue at the starter.
battery,cables,corrision or possibly a faulty solenoid.
I haven't replaced mine but can you jump the started from another source using jumper cables.Mind you that would bypass your trucks switching so it would turn over imediately, so take major safety precautions!
Also a volt meter would come in handy.
