Well guys here's my story. The 5th of July, I bought my first car a 2004 Camry with 160 000 km which is around 100k miles. Paid 3.5k cash CAD$ from a garage. It seemed like a good deal and I got it checked/inspected at another garage where my stepdad was working. Missing Link kit and only ac blowing warm air to have fixed. They fixed it and I bought it the very next day. I was pretty desperate because I have been biking to work everyday for 20 minutes during raining days and thunderstorms...
It’s been 6 days that I’ve had the car under my name and I filled the tank to full with 100$ and 150km (93 miles) later I’m almost out of gas 1/4. I went to see the my stepdad and he said the gas tank is faulty and has oil leaking out. Went to the garage who sold me the car and they said that everything is fine and that it’s normal. I tried telling him that it really wasn't but he didn't care, he already has my cash and with no contract or sellers agreement whatsoever he won't go out of his way to fix it. Soo far on the first full tank fuel up I'm getting approximately 6.77 mpg or 2.9 km/L.
It sucks but I'm glad to finally have a car. I was really looking forward to working on all the scratches and rust on the car and cleaning the interior but I have bigger issues to deal with right now unfortunately. the issue is most likely a gas leak combined with horrendous gas economy.
*The odometer is in kilometers because I am living in Canada, Qc
- What can I say about the car. It idles at 1k rpm, I notice the Gas gauge go down a bit when starting the car in the mornings and it also smells like gas when I start it up in the mornings and when I stop at a light with my windows rolled down I can smell the gas again. It also has a tiny bit of white smoke that comes out when I start it.( around this much).
The mechanic say that there is a leak or crack in this part of the Fuel tank and says that it smells of fuel but it is not leaking and does not have any smell when I rubbed my hands against it and smelt it. I will be posting an image of the actual fuel tank later. But for now, This is where he said it was leaking from.
*Where the metals of each side kind of touch. and are sealing the tank
I know that I should probably listen to the mechanic, but I want to try out any other possible options that won't be costing me an arm and a leg to fix.
-Which is why I am also going to try check the pcv valve and change it if necessary.
I have been looking under my car every day for and drips or leaks when I move it in the morning and I never see anything.
Other than all of this I'm open to any other ideas that you guys might have. I drive pretty conservatively as in don't try to press the gas too fast and don't really use A/C that much. My commute is 10 minutes of city driving which is pretty short, but it still doesn't explain 7mpg or 3km/L.
*Edit 12/07/2022
After going to work, then Canadian tire to get the price for a carburation system inspection(60$) and back. I've driven 10 km total and can visibly see the tank has gone down on the fuel gage. Here is the picture taken 10 minutes ago the 12th of July.
EDIT ***
First of all, I would like to thank you guys for the comments and advice. I have posted this issue on reddit aswell and have had more or less good people giving me tips on how to solve the issue because like most of you guys deducted there is more than just the tank or some other reason as to why I'm losing soo much gas. I will be giving you guys the reddit link because I will be updating mostly over there since there are simple more people with more ideas not that they're better since you guys mostly all have Camry's or understand them well and better than redditors.
I had sadly found out that the Dash lights have been messed with CEL not working ABS not working Engine Maintenant not working. Soo I have alot of issues to find and fix for myself when I get an OBD2 Sensor.
I am between buying the Blue driver or
The obd mx plus (Suggested by a mechanic)
Here is the reddit link guys and thank you again for the help!
- I have checked the Air filter and its brand new.
- The o2 sensor looks pretty clean, but I will be purchasing a CRC 05110 Mass Air Flow Sensor Cleaner
- I'm going to clean the Throttle Body with CRC 05078 Throttle Body and Air-Intake Cleaner
- I have bought Mobil 1 High Mileage Synthetic oil to change soon, because the oil is kinda black/dirty but I am waiting to receive an Oil Filter the Purolator PL14477 ONE to be exact and I also am trying to find the right washer and screw or bolt to replace the old one.
- I am going to change the Cabin Air filter tomorrow when I receive it
- I will try to purchase an OBD2 scanner with live data stream” and evap test or o2 sensor test as well
*Edit 12/07/2022
EDIT ***
