Help- is there different lower grade Toyota parts “tsmc”??
1.5K views 10 replies 7 participants last post by  jjabrahams
I am needing brakes and last time I specifically asked Toyota if Knoxville to use genuine Toyota parts I found out later they used NAPA parts and still charged me $730.00 for front brakes and rotors- service manager doesn’t care..
So I want to get the parts myself and take them somewhere else, but I’ve “heard” there are lower grade parts for cars that come with free service for so many years… I want genuine real top quality and I even researched the 2010 Lexus ES350 is the exact same parts on APA website, so could I order from Lexus to get higher grade material for pads and rotors? I am extremely hard on brakes and travel 92 miles one way through the blue ridge mountains to Asheville from Knoxville daily so these Napa crap parts have my whole dashboard shaking as soon as they heat up which is about to good down slope curves…….. ok, so??
So after a long and frank conversation with parts manager at Lexus Knoxville, I am correct in different grades of parts- I have been told that the junk stuff they use for free factory maintenance and brake specials always start with a “AZ” prelude to the numbers-
Yes the Camry and ES can share rotors and pads however the ES has a different part number than the Camry rotors. He can not tell me if it’s a physical difference as in fit, or quality
For Camry rotors v6’s from factory VIN verified-
4351206150- $141.83 EACH
ES350-
4351233140- $158.13 EACH
Brake pads are identical #’s from factory-
0446533471- 127.00 EACH
So does anyone know what makes a different part number for the ES rotors since NAPA site and several others, rock auto, all say it’s the same part-
So I want to know what the difference is-
2010 Camry XLE V6 w/Nav
VS
2010 ES350
Only difference in the two when cross comparison is the Lex has a 8 way power seats and mines 6, all other features are in my Camry the same. He admitted the Camry shares 84% of parts with the ES350.
Napa crap parts
Which, of course, is not a valid statement, anyway. In almost all categories NAPA makes parts from "basic" to "deluxe."
But even that's beside the point, as someone pointed out already your self-reported driving style is, shall we say, spirited. Companies like Brembo, as but one example, exist because if your driving style pushes the limits, or goes beyond the limits, of most people's daily driving style they can fit you out with equipment that matches yours.
If you want brakes that perform in conditions that you impose on them, look to aftermarket companies that specialize in high performance brakes that can be fitted to your specific make and model.
#11 ·
Free maintenance is a lowest price max profit type of deal. If this was warranty work, yes dealer would need to replace with OEM parts, but maintenance is upto the end customer and if they actually ask about what type of parts are going in at the time of service printed on the service order before the car is released to the dealer to complete the work.
Regardless of parts used, its upto the repair shop to make things right ( I assume toyota of all places have a warranty right). You mentioned free maintenance, i assume they can repair theyre own repair.
I would skip looking for toyota or lexus parts. What I would do, is go to a shop you can trust, or ask around for a shop reference. They can help you actually fix the problem.
If you feel vibrations in the steering wheel, I assume the rotors have some kind of pad deposit causing high spots. You drove the blue ridge highway which is fairly taxing for the braking system. You could try at your own risk while following local road laws a couple of bed in procedures. Toyota has a TSB that mentions their protocol (one can bed in at varying speeds according to them). If that does not work, then source the following:
EBC slotted and dimpled rotors
EBC greenstuff or redstuff.
Ask the mechanic to inspect and replace any faulty brake hardware. Make sure new brake clips, lube the pins and check for anything frozen.
That should be the ultimate combo without sizing up a new rotor. If the mechanic just does a pad and rotor slap, then you'll end up with vibrations and more issues after this. Again brakes are not just rotors and pads, its a complete system.
