For 2015 Highlander XLE, my roof rail trim (silver, runs parallel to the vehicle) is just 2-3mm forward. When removing the trim cover plates to expose the roof screw holes to install a roof rack (mine happens to be a Yakima rack but would apply to any rack), the roof screw holes are not in the center of the rail trim opening--they are off by just enough that the roof rack towers don't line up with the screw hole. All 4 locations (driver and passenger side, front and back) affected.
Anyone else have this problem?
Took it to a dealership, they agreed, both sides are just barely off. They suggest remove trim and reinstall ($1700). Obviously installed incorrectly from manufacturer, Toyota Brand Engagement Center says they'll not cover it because warranty is up, and they have no other cases of this. Looking for those other cases, find me if you're out there, wandering rackless and afraid.
Otherwise solutions welcome (other than the obvious one of forking over $1700).
Thanks!
Thanks!
