My horn doesn't work. The PO turned the truck into a full prerunner, including cutting back the unused wires (horn included). I cut back the electrical tape, and found what I am fairly certain is the horn wire on both sides of the engine compartment.
The horn I have is a Grant unit, and I have plugged the horn into the plug in the steering column. When depressed, there is no click of a relay anywhere, so I assume it is bad or not present. I have checjked continuity from the horn button to the steering column connector, so I know there is flow into the wiring harness.
After some digging around, I found a slot next to the drivers side kick panel relay block that is vacant. It has QTY4 wires leading out of the rear, and has 4 slots on the front.
All the research I have done has shown a 3-pin relay for the horn, so I am not sure what it could be.
Anybody have any insight into what this relay location should control and/or why my horn isn't working?
TIA for any assistance!
Vacant relay is in the top right of this picture:
Vacant relay rear side:
