how can I disable one sliding door and leave the other
1 reading
11K views 5 replies 3 participants last post by  MrCamryLE
Can some one tell me how to deactivate one power sliding door and leave the other working?
I have a 2007 Sienna LE (Package 4 comes with 2 power sliding doors just like the XLE), and the cable of the passenger side door broke, I did a quick fix and I cut the visible part of the cable and now the door is moved manually.
The problem here, the kids keep pushing the button of the broken side activating the motor which keeps rolling the rest of the broken hidden part of the cable around the spool (reel) and I'm afraid it's going to do more damage to other parts. That's why I disabled both doors by the dash button.
I'm planing to change the cable in the near future but in the mean time I have both doors disabled through the dash button to protect the broken door motor and spool.
Is there a way to disable the Passenger side power door and leave the driver side active?
You might be able to pop out the button and disconnect the harness (wiring) to the button so your kids won't keep messing with it. Keep in mind I'm not sure if this will disable the entire circuit because its no longer connected. Maybe other can chime in. If it's like the power window circuit, if one of the passenger button is disconnected, it should be still functional. Now if it was the main button, different story.
That was the first thing I did since no tool required. I pulled the column cover and unplugged the button. I assumed it's gonna kill the electric circuit, no it did not:frown:. With the button unplugged, the sliding door shut, and me inside the van I opened the door with the interior door handle, the door handle triggered the motor and I heard some sounds :frown:
Latching and sliding are two different and independent processes. Both cables on mine were cut by the previous owner but the door still latches with a motor if it isn't shut all the way manually. And latching is automatic.
Try it: Open the door from the outside and then close it but don't latch it. The door should latch itself. Mine's been like that for years and there's never been a problem. Just because the door is automatically latching doesn't mean the slider spool is operating.
Problem solved.
The slide and the latch are moved by to different motors. I removed the panel and reached the motor that rotates the cable spool and unplugged it. Also I unplugged the little tiny motor close to the door handle, the one that trigger the cable motor. And of course, the column button was unplugged first. Now the door will stay manual till I get the time to fix it while the other side is still powered.
