How does "mp3/wma playback capability" work?
30K views 15 replies 9 participants last post by  ve015891
Does this mean the CD player can play mp3s? i.e. so you can fit hundreds of mp3's opposed to 20 or so u normally fit on an 'audio cd'?
...how does that 'folder button' work?
i tried burning a CD of mp3's in folders.. but it did not detect any audio
please explain how this works ?!
ve015891 said:
thanks wireless, i read that but it didnt help much.
i stilll cant get mp3's to work? even w the .m3u playlist file
im using cd-rw btw
There is your problem...99% of automotive CD players will not play back a cd-rw, only cd-r. IIRC it is covered in the thread I linked.
Ah.. my bad. i need to go back gr5
so, w/o wasting a cd-r, can i do this:
create a playlist .m3u with all songs i plan to burn on cd
make a 'data cd' with the .m3u playlist file, and folders which contain mp3's for each music album
will that work??
thanks in advance,
sorry for my ignorance
#7 · (Edited)
I can tell you that I have used CD-RW on the stereo on my 07 Camry stock non-JBL head unit. It may be the brand of CD-RW that you are using. I have used several Verbatim discs.
I haven't tried burning M3Us so I don't know if those would work at all. I put music in folders and the unit will play music one folder at a time.
I have tried Memorex CD-RWs and the only consistent thing, that I have noticed, is that they suck - literally. They are like black holes for data. You can write data to them but good luck retrieving anything.
#8 · (Edited)
to burn the data CD's i just used windows explorer (drag and drop). Do i have to use a program that has the 'burn a mp3 cd' option? i know itunes can do that, but i duno if the folders thing would work then. i'd like that folder setup so i can switch albums with the folder buttons on the deck
its interesting that some cd-rw's work as touringcamry just said. i tried making data CD's with imation and TDK rw's (with and without the playlist file). neither worked. it said "no music found"
i tried burning a data cd with folders with mp3's inside (no playlist file) on a CD-R... didnt work it said "error 1"
#9 ·
Do you have something other than Windows to burn the CD with? Are you burning using ISO format, packet writing or Mt Rainier or something like that? If you are using ISO1 or ISO2 aka ISO 9660 or 9660:1999
Ensure that you use disc at once and finalize the disc. Do not use multi-session.
I use Itunes. Create a playlist. Drag songs you want into the playlist. Right click-choose burn to disc. Make sure properties ar set to burn as MP3. I use CD-Rs. Never had a problem.
I love the mp3 option I have (6) main playlist on my ipod I burn those playlist onto disk. I don't even need the aux input.
#11 ·
If i'm not mistaken, windows will not allow you to burn MP3 cd's. Use some software. I use Nero, from there you can click either "create MP3 cd" or "create data cd". It would do the same thing. You can have folders, and then you can flip through them on your stereo unit.
i have a 2007 camry LE. I use nero to burn my mp3s as a data on a cd-rw and it plays perfectly on my camry. It even allows me to use folders to seperate types of songs.
it is probably 90% the brand or type of cdrw your using, and 10% the burner program u use and whether or not u use "burn as data files".
#13 ·
I use Windows drag-and-drop to burn my MP3 (actually, I use WMA) CD's and they work just fine in my Camry.
Does the music you are using have DRM on it? In that case, it won't work.
#14 ·
Of course, they will work fine. WMA is a windows media file, so it WILL burn that. But try burning MP3's. I might be wrong, but i'm pretty sure it wont let you do that.
I've been using the aux port with my iPod, I'm going to try the above method. Thanks T4CAMRY!
