How many amps does the stock alternator put out?
1 reading
36K views 17 replies 9 participants last post by  DHayes23
On the 2.5l specifically (I have a 2019, ignore my username)
Does anyone made high output alternators yet?
I'm going to add a subwoofer and I want to be able to play my very bass heavy music without running into issues. Otherwise why even bother?
So does anyone know? Thanks
1 sub? SVC or DVC? subwoofer ohms? if DVC series or parallel?
I am pretty sure its ~100amps for the 4 cyl. Its too new of a vehicle to have unlimited aftermarket options. You can contact the aftermarket alternator manufacturers and see if anything is in development. Or, you can grab a salvage yard alternator and send it to an armature shop or alternator rebuilder for R&D.
Install an accurate voltmeter that you monitor and plan on keeping volume lower than normal, or bass turned down some until you determine if you have enough alternator. Get a 2nd battery for the amp.
msingeralternator@gmail.com
Tue, Mar 10, 2020 at 3:52 PM
perfect thank you! it does
I offer any of these options that can work in the OEM position
for your vehicle w/ just adjusting the belt size smaller is all for the overdrive pulley
120MM hairpin case (denso 6 phase hairpin)
MDL PRICE IDLE OUTPUT
180A $399 140A (200A peak)
200A $449 140A (220A peak)
260A $489 145A (285A peak)
300A $549 150A (320A peak)
All alternators come with a lifetime warranty on labor
and one year included on components. powder coat is optional for $48
On Tue, Mar 10, 2020 at 3:38 PM
Hope this helps. Here's what I found online from a local dealer:
2019 Toyota Alternator assembly. Battery, replaced, engine - 27060F0010 - Genuine Toyota Part
On Tuesday, March 10, 2020, 3:31:47 PM EDT, Michael Singer <msingeralternator@gmail.com> wrote:
HI
can you send me an original part # on the OEM alt?
i show two cases for this vehicle for some reason
#16 ·
When I purchased my H/O alt for my 18 Camry it was the first time getting into the "electrical" side of car audio builds. I wish I would've known then what I know now in regards to voltage regulators and pcm controlled alts. I would've had it built with the voltage setpoint regulator to bypass the pcm. That would prevent my voltage drop issue. Started with an agm under the hood and two in the trunk. Switched to 49.5ah lithium bank and still dropping. We'll see if replacing the regulator will fix it.
