How do I connect this ↓ to Camry 2002 Fuse Box - down, to the left of the steering wheel? Where do the red & black go?
Have you used a volt meter to verify there is power at the plug that attaches to the back of the accessory socket from the car?1. One is for a car where the cig lighter blew out when an air compressor was used. That car has zero working cig lighters. I thought I would use the amp kit to connect battery to the 12V Power Outlet.
Using the inside fuse block, I would use #4, as it should be off with the ignition switch being off.The burnt socket is on the other car, Subaru Baja 2003 and yes, Subaru dealership wants $150 to fix it precisely because there is a fuse on the back of the original socket and no other socket will work. That is why I thought I would use a new power wire plus socket pictured in post#1 instead for that car. I understand with new wire and new fuse that comes inside an amp kit, I can run whatever I want off of it safely and comfortably.
I do also want to install the power socket off of the Fuse Box. Thank you kindly for the instructions on Fuse Box, you are the first person on multiple forums to give me this info this week. Your post above was Gold!
I did an search for "Fuse Tap Adaptor Adapter" and it all makes sense now. That was key to the solution of this problem. Thank you.
No real need to have it on all the time, I thought it would be used only when car is running. So which Fuse should I tap on each car. Camry has power seats, but not Baja. THey both have power windows. Camry has power door mirrors too. I think Baja does too.
• Toyota Camry 2002:
• Subaru Baja 2003:
Your application isn't what the "engineer/manufacture" had in mind. Cut off the wrong ends and put the correct ones on.If you look at the picture in post #1, it looks like the the connector from the red wire is really needed on the black wire and vice versa.
Why did they make it like that since it sounds like "loop type wire lug" is on the red wire instead of the black one. And what's on the black wire looks to be exactly what's need on the red for the fuse tap, doesn't it?
This 41 cent piece is all I need, correct?:
http://www.oreillyauto.com/site/c/detail/BWD0/CT123.oap?
The clip the you linked to, in your last post is for the older glass cartridge fuses. (Note the curved end.)How do I connect this ↓ to Camry 2002 Fuse Box - down, to the left of the steering wheel? Where do the red & black go?
I would call a heavy load anything above the fuse rating, divided by 2, to the limit of the fuse, because that is what the wiring from the fuse is rated for, as far as maximum current. Any device you add on needs to be added to the current that would normally be drawn, when the OEM device is operating on that circuit.Once again, thank you Luna2. I understand what you are saying.
As for gdanaher's post, here's the whole story, followed by questions that apply to my case and not any case out there:
1. If all you want is to connect a radar detector and nothing else *ever* to an unused 20A fuse, then everything is OK and the car won't burn down, if everything is done just as I pictured it above, correct?
[And just out of curiosity Luna2, what constitutes a "heavy load"?]
2. Separate question, separate car:
I want to use a wire from an amp kit, connect the wire to battery, running the wire through the fuse that came with the amp kit directly to the cigarette lighter and thereby fix a broken cigarette lighter issue in a separate car. Can I do that and if yes, which cig lighter can I connect to? Any?
How about the car's broken Subaru Baja cig lighter socket which does not work because Subaru put a fuse right on it and it blew and it *cannot* be replaced using anything other than their $150 cig lighter socket part, but let's not get into that, can I simply connect the amp kit wire through the amp kit fuse, to the original broken cig lighter socket?
