How to open SD Card slot
2 reading
50K views 16 replies 8 participants last post by  dotjiris
2018 Tacoma Off Road. Want to update navigation maps. So, on the right bottom side of the screen there is a micro door or slot. I don't know how to open it in order to put a newer SD Card in. Got any help? Nothing online for my vehicle. Only how to use the navigation system.
Found this in the archives.
"Installation couldn't have been easier (2017 Toyota Avalon). Turned off car, removed original micro SD card (I needed a small screwdriver to pry open the map data cover, it opens like a book with the hinged side on the left). Removed old card, inserted new card, and restarted car. The screen recognized that new softward was available and instructed me to turn the car off and then back on to start installation. The software loaded in less than 10 minutes with a progress bar to let you know the progress. Once installed everything worked normally."
The manual is very vague on it. It portrays it as being explanatory.
Just don't force it, I'm sure an owner will speak up. :)
I tried it on my truck sitting at a light this morning. I have the same head unit you do. I was feeling around for a place to try to pry it off, and by accident I found that if you press on the right end of the cover, it pops open from the left and then you can grab the left side. No tools needed.
#9 ·
You have to push on the right like toto stated earlier. I did that and replaced the SD Card 2014 2015 2016 2017 2018 2019 Toyota Latest Navigation Micro SD Card 86271-0E072 and it made no diferemce. That is, it did not update the navigation system. Which tells me the SD Card that I had from 2018 is the most current one.
#11 ·
