How to remove plastic chrome trim above rear Plate
1 reading
9.4K views 5 replies 3 participants last post by  Avalon&CamryOwner
2003 XLS
Installing a rear-view camera.
Need to route cable into trunk behind the chrome trim piece above the rear license plate.
I already have the inner panel loose, but I can't clearly see how to temporarily remove the chrome trim piece above the plate
Is it held in place solely by the (sorta circular) plastic spring clips?
If so, any suggestions on how to compress them (especially since it appears that a couple are beneath a steel body piece in the center).
Thanks in advance for any assistance.
I finally got it removed without further assistance.
My bad:
In addition to the 3 circular "push-pins" AND the 10 mm nuts I found there was also some super-sticky double faced tape holding the piece to the trunk.
Firm, slow pressure prying with plastic body tool eventually got it free.
The tape was SO tacky, that it felt like there was some other fastener I had missed.
I took the chrome piece off then realized I should have just routed by the license plate light covers, but I used a license plate frame type. Here's my thread: Just picked up a 2003 XLS, white.
Can you please post a pic of what you wish you had done? I can’t really visualize it. I kinda don’t want to have to remove that chrome trim.
I sorta did the same thing. I ran out and got rubber grommets that would barely fit over the RCA plugs and THEN realized they wouldn't fit over the square box that's about a 1/2" square about 24" up the cable.... another DUH moment.
I did a slight mod from your method.
I elected to remove the license plate light-box and dremel-tooled a small notch in the side of the plastic case. That way. I figured the plastic wouldn't need to prime-painted like a metal cut would to prevent rust. I'm guessing that since the heat from the license-plate lamp doesn't melt the basic styrene lamp housing, it shouldn't melt a plastic cable routed around the far corner. The light-housing and the cable are two totally different types of plastic, but I can't imagine that the side of the lamp housing will get hot enough to be a problem.
I'll attach a pic if it works out. Obviously, I haven't reinstalled the chrome "garnish" piece yet. (I found out that is what Toyota actually calls the chrome piece.)
