How to test ignition coil pack!
4.5K views 4 replies 2 participants last post by  thomas2002tii
My 2001 Camry got code p0300 . I am going to change spark plug and ignition coil pack. Can anyone show me to test the coil if good or bad before I buy new one . Other than plug and coil. What else I need to focus to fix code o0300! Thanks very much!!!
Usually with a spark plug gap tester. "Fancy" isn't always better - a basic tester, or removing spark plug / checking against engine ground will allow you to see the 'quality' of the spark (bright/blue, vs. dull/yellow), an indicator of ignition wire & coil health.
re: "how do I fix code P0300?" - well, P0300 is a "generic" misfire code, and can be triggered by several different causes, including ignition system issue(s), fuel delivery or injector issue, or air delivery (vacuum / leak) issue.
Before "throwing parts" at the DTC (issue), best to do some diagnostic to narrow down / identify the actual issue.
Here's a YT video of some different spark plug gap testers, all will allow to "see" if the coil is firing, a few will also show "quality" of the spark.
Update! Remove and try to clean plug? These not original one. It should original double prong! Anyway put them back and drive for 1 day This morning start engine and no check engine light!!!
So I guess cause not original plug single prong! I am going to change to original with double prong soon!
Thanks for all help!
