How to tie down a Canoe - HighLander 2022
9.8K views 29 replies 9 participants last post by  ihtus
Hey,
How do you guys tie down the front of the canoe to the car?
On the photo - showing how I did on my old Honda CRV.
Attached the straps under the front bumper, to the towing 'hooks'.
Attaching to the hood - not an option for me, don't want to deform the hood.
Looks like Highlander doesn't have any exposed tow hooks that I can use (as I did on CRV).
The option that I have in mind - to screw in towing hooks on the front bumper (see image).
That means I need to remove those plastic caps, screw in towing hooks and attached the straps to those hooks.
Any other ideas?
Please share your photos of how you tied down your canoe.
Thanks
#11 ·
I think you'll need to attach the line to something substantial under the cover. Just leave the covers off when you do that, although I don't know how you'd attach the line as there's nothing under the cover except the blank front of the bumper structural member.
I'm surprised that the front end of your CRV didn't crumple or deform from those straps! If you're gonna go through the tow hook covers, just leave them off like Sporan said. But the issue is that if you try strapping all over the plastic like that, it will break it. That bull bar looks like the best option, so you can tie to that and hope the hood doesn't crumple.
#14 ·
I never use front or rear tie-downs. I use Yakima racks - old school, and tie down to the rack bars. That's for a 14' canoe, on a 2004 Camry. I most frequently carry the canoe for work, as my company does goose harassment. Sometimes we have to go to the water. I don't like kayaks, and I can't fit 2 dogs in a kayak, so, a canoe. I've driven that way up to 40 miles or so on the freeway. It works.
#17 ·
@ihtus ,
As requested, here is the picture of what I used to tie the canoe on my avatar picture:
Those are about 1.5 inch wide. Sadly I do not have a picture of the anchor attached to the vehicule and since it got stolen in 2009, I can't take a new picture. On my new canoe-carrying vehicle, I have to tow hook so I use that instead.
The closest I can find is at Princess Auto, but those require 2 holes, which mean drilling a hole somewhere under the Highlander. :( The one shown above has the metal structure with the hole folded on itself, so I could only remove an existing bolt and add it (or use and existing hole and add a plastic retainer to screw the anchor).
Good luck!
jf
#22 · (Edited)
#24 ·
Interesting that your collision sensor was affected. It's a radar behind the badge and though I haven't tried it yet, I assumed non-conductive materials wouldn't bother it. What foam and rope did you use? Maybe black foam pipe insulation might have enough carbon black in it to cause a problem
#27 ·
Yeah. I think it uses the radar for distance and closing speed and the camera for azimuth and lateral motion. My previous Subaru used two cameras spaced on either side of the rear view mirror for both, essentailly binocular vision. It did a much better job of adaptive cruise, collision warning, and lane centering than the Toyo. That may be down to the implementation rather than the methodology.
