Ok...real quick...I had a bad tank, I ordered a new tank from a company on EBAY.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7981061243
Tank came in Tuesday and I install it that night. The only problems I saw at the time when I installed it was that on the fuel filler neck, the neck didn't properly line up with the screw holes in the tank therefor I was only able to get 3 out of the 5 screws installed though the 3 that did go in were able to do the job. Alright, now for the fun part. Yesterday I got home from work after the first day of the new tank...I smelt gas when I pulled into the drive way. Popped the hood and saw that my Charcoal canister was leaking gas badly. Took it out and inspected it, and couldn't find any problem. No more leaks for the rest of the night. Today I get home from work and again I smell gas so I hop out of the car and I can see gas pouring out from the canister again. *parked on a slight hill* I opened the gas cap to release presure and in turn I found out that gas started comming out of the gas inlet *where you pump* So I closed it back. Opened it a few more times to slowly release pressure and got it to stop leaking gas. Then went on to check the fuel pump because I wanted to look at something inside the tank *for the evap line* and when I disconnected the hoses gas started coming out the return and main lines on the fuel pump, so I closed them back off. Finally I moved my car into the garage *with fans blowing* and opend the cap again. No gas this time. I was able to remove the main and return lines with no gas comming out this time around. So now for my question....WHAT THE HELL IS GOING ON HERE? Does any of this make sense to anyone? I had just filled up the tank yesterday afternoon so it's a full tank now. Can anyone please hit me back ASAP so that I can get some ideas on this while I'm working in the garage?
