Just scratching my head over this one. Has anyone noticed that the in gen3 - 3.5's, the I4's have bigger sway bars than the V6's. Why is that? My guess is the heavier V6's have stronger spring rates, they don't need as bigger bars. However, if one has stronger spring, and smaller sway bars, and the other has softer spring, and bigger sway bars, wouldn't that give both the V6, and the I4 the same level of handling? There's not that much difference between the front sway bars. About 23mm front for the V6, and about 24mm front for the I4. However, the rear bar is much bigger in the the I4. About 15mm for the V6, and 17mm for the I4. The only exception would be the SE V6 which uses a 17mm bar just like the I4.
So then, if I had the V6 (which I don't), couldn't I just install the front and rear sway bars from an I4 on my V6. Or, are there major differences in the chassis configuration between the I4 and V6 that wouldn't allow the swap?
I don't see any major differences, but I've been wrong before.
I don't know, just somthing I've thinking about the past few days.
