Hi all, new guy on the block.
I'm having the same problem as Bando on the timing issue. It's an 88 GT-S. I just replaced the timing belt, due to shredding the teeth off the old one. I have matched the crank and camshaft marks per spec. I set the timing per spec and method but it bogs til about 2K rpm then lacks power until ~4K rpm.
I set the timing to 20Deg BTDC and it runs fine in all rpm ranges. Will this setting have neg effects on the engine life?
Have replaced cap, rotor, plugs, air filter, spk wires good to spec.
If the previous owner changed the cams( I owned her for 3mos.), will this change the timing requirements as well?
