Installation of Reverse Glow Gauges
1.7K views 9 replies 8 participants last post by  Paul95
I have a 99 Camry 4cylinder and just got reverse glow gauges but there are no directions. Does anybody know how to install them. If so it would be very much appreciated. Thanks
1. Take off the instrument panel trim
2. Take out the 4 screws that hold in the gauge cluster
3. Unplug the gauge cluster
4. Take the plastic cover off the front of the gauge cluster
5. Slip the new gauges over the old ones, make sure not to bend the needles.
6. Put the plastic cover back on the gauge cluster
7. Make sure that the wires are all coming out of the top of the gauge cluster evenly.
8. Attach the ground wire to the metal underdash
9. Wire the power wire into the rear tailight fuse
10. Put the gauge cluster back in and put the instrument panel trim back
11. Check to make sure it all works( you can do this before you put it all together just to be sure).
I'm gonna temporarily hijack this thread- anyone seen gen2 I4 indiglos with tach yet? I've never seen them personally
Steve
