hello all. i have a quick question. i am planning on installing an autometer temp gauge in my car, as i beleive the stock gauge does not function properly. i remember seeing 230 on an obd2 scanner and another time seeing steam pouring out from underhood, gauge never went past half. (yes the head gasket was blown, previous owner cooked it pretty bad, currently in the process of fixing it) So i am gonna install an aftermarket one. on the generic install video it says to mount the sensor in an empty coolant hole, like on the intake, but if i remember correctly, there is no coolant flow through the manifold. i wanted to try a radiator hose adapter for the sensor, but the only ones autometer sells wont fit the stock hose. i was thinking about removing the fan switch on the thermostat housing (doesnt work anyway) and putting it there. the fan is already set to run all the time. would it fit there? has anyone else ever done this before? is there a better place for this to go than there? something im missing?
are there any other hose adapters that will work for an autometer gauge?
1997 Geo Prizm 1.6 3spd auto
