It seems all usable terminals on exterior fuse box constantly supplies power to car, while car key is not in ACC mode.
4.8K views 2 replies 3 participants last post by  Esso
If this is the case, then this is unfortunate.
I'm trying to hook up a 2nd dash cam, and wanted to save other spots in the interior for a later time, and wanted to avoid using the ECU fuse of the interior fuse box.
The one labeled audio in the exterior, is unusable due to obstruction from the 2 relay switches.
I'm wondering if its just me or there is a way to circumvent this? Otherwise only logical choce is to use T-Taps.
There is no audio fuse in the under hood fuse box. There’s a circuit labeled radio under the dash.
You will have refer to the specs from the manufacturer on how to wire it. You may find it easier to use a relay instead.
