Hey guys,
2002 Highlander 4wd v6 currently at 273,000 miles
Going to replace both from control arms, and inner and outer tie rods.
Started with the passanger side I got the engine jacked up motor mount out and was taking out the last bolt holding the arm on (under engine mount) and it started to spin. I went under the car and noticed after poking at it a spot rusted through. I cut out enough to get heat on the square nut and get the bolt out, but now I am worried the subframe is compromised to the point of a safety concern. I drive 500-1000 miles a week for work in the car and really just want to get another year or two out of it before I go for a newer car.
The top part of the subframe seems fine, it's just the bottom as you see in photos.
After looking at the pics can you guys give me some insight on how to tackle this issue? I'm tempted to complete my install and perhaps weld up the rusted portion under after I'm done but I'm really not sure if it's even a) nessesary or b) even worth doing and perhaps I should try getting a new subframe (quotes $250 if they can find a good one) but undertaking that kind of project seems alittle far fetched for how old the car is.
What do you guys think??!
