Lifespan of a 2.2 Camry starter?
5K views 13 replies 11 participants last post by  silvercamry2011
What is the lifespan of a 2.2 Camry starter? How many miles did you factory starter last?
These OE Toyota/Denso starters are durable products. I have/had four Gen 3/4 Camrys in my family, all driven by my kids and all purchased when they had between 150K -185K miles or so. Never had a problem with these OE Denso starters. If they do go bad, usually it's the starter solenoid contact points that need to be replaced after many miles (not in my family's case), which is a cheap fix.
This is one of those parts that if it does go bad, you would probably get a better used Toyota/Denso starter at a junkyard for 1/3 the money than you would buying a rebuilt starter from the typical chain auto parts stores.
Probably mileage is not a reliable predictor of starter life. To illustrate, UPS requires their drivers to stop the engine and remove the keys on every stop, then restart when they return to the vehicle. Those starters will require repair at much lower mileage than on a vehicle driven 60 miles between stops. I just replaced one on a Camry with 197K miles that had considerable miles driven between stops.
Another reason for failure is pitted points in the solenoid, it also gives few days of warning that the solenoid will just click and won't rotate the starter, you do it repeatedly and it will start the engine, consider this enough warning.
Just like the battery, it gives you a warning of less than 24 hrs, astute drivers can notice a slow starter, its a dead giveaway that the battery is gone, replace it right away, not even next day.
#13 ·
OP, the Denso starters are very durable. A weak point, if it is a weak point, are the contacts in the starter solenoid. It's an easy repair even for a beginner, using basic hand tools. Replacement contacts are available on Ebay, Rock Auto and supposedly dealership parts departments, although when I inquired there the counter man looked at me like I had two heads. Good write up in the DIY here and also YouTube videos. I've done both of mine and I'd rather do that then take a chance on some Chinese junk or a "rebuilt" that came from who knows where.
#14 ·
I have resurfaced pitted points in two starters, both in Hondas as I didn't know that you could get new points. That worked out well. Opening the solenoids is not easy as the body is crimped and later the closing is not as good either. Replacing points would still leave one weak point i.e. brushes so probably both should be replaced at the same time.
