Locking Car while it is Warming up
59K views 26 replies 20 participants last post by  Marly70
We have a 2015 XLE. Is there a way to start the car, lock it, go back in the house so I can get my kids' coats on while the car warms up?
When I try this, either by locking by touching the ribs on the handle or using the remote, the car won't let me lock it. When I tested it by starting the car and going in the house with the key, the car remains running and unlocked and could easily be taken by anyone... at least up until they turn it off.
Thoughts?
Thanks in advance.
#17 ·
This. I bit the bullet and had this put on mine. It really is worth the money, especially when the darn polar vortex causes the high temp to be -5!
The car will not shut off based on Key Fob location.
I am assuming that you have a push-button start. Both of my cars are push-button start and this is what I do when I want keep them running and lock them...
1. Start the Car
2. Open drivers side window
3. Get out and shut the door
4. Standing outside, Lock the car via the door lock button inside the car
5. Again, Standing outside, Close the window via the Auto up function inside the car
6. Walk away
When I return, I use the key that is in the key fob to manually unlock the door.
This sounds so bootleg, but way to think outside the box! :p:
1. Start the Car
6. Walk away
http://www.toyotanation.com/forum/1...camry-hybrid/696065-how-do-i-lock-my-doors-keep-engine-running.html#post8321754
What you might want to do and should work is to remove the mechanical key from the fob and have a blank key cut - http://www.ebay.com/itm/BLADE-SPARE...mart-Key-Blade-For-Avalon-Camry-Corolla-Highlander-4Runner-Prius-/221262827741? - they should have a standard style key like this that you could have cut, but I don't know what your key looks like.
Then you can either have that on a quick-release keychain or on a separate keychain so you can use it to lock and unlock the car with it running.
#9 ·
It would definitely suck to drive far away and realize that you left the key at home; in winter and in Canada. That would be something. Not sure why they would not program to make the car refuse to drive away ( no gear shift) if the key is not present.
You know, I have not get my car yet and it will be my first ever push-start car and this came across my mind. What if I drive the car and forget the key in a pocket at home in winter. What would happen? Now I know.
#14 ·
They have tried to prevent you from driving the car without the key by not allowing it to start without it. Then we are coming up with all kinds of ways to fool the car into locking the doors while it is running and we're worried about leaving the keys at home and blaming design? Imagine if you didn't have the key and the car shut off while driving? Cannot happen. Car will run till you push the button.
Agreed with all points, but some of the early systems were more poorly thought out. I know some of the early Fords woudln't start without the key Fob, but if you left the Fob in the kitchen - it was "in range" to start the car and there was no warning until you left work and tried to start it and realized you didn't have the fob with you.
(New Fords do give you a No Fob Present warning.)
#18 ·
It's a bit out of the norm to lock through the window...but I don't really use this for warming up the car. Our Highlander is a Hybrid, and on trips, my wife usually ends up in the back sitting between the kids. Since she can't really reach the front doors from the back and I don't like to shut the vehicle off since the engine shuts off most of the time, this method works great for me.
#22 ·
a word of caution, because it happened to me. luckily i did't have to walk far as the Lowe's food store, and the Lowe's home store were close together. i had dropped my wife off to food shop while i drove over to the home store. when i came out, i couldn't start the car and realized i forgot my smart key. (my wife had hers but i forgot mine) and i had to walk quite a ways to get her key. the car will not shut off automatically when out of range of the smart key!!
#24 ·
I just do the manual key lock thing when I need to leave the car running with the dog inside. On a side note, The key is pretty good at knowing when it is in and out of the car, but not in every case. I had my oil changed at a Jiffy Lube. When I went to get my car, they drove it out and left it running, so I hopped in and left. I figured the key was in the car where I left it, in the drink holder. When I got home and turned the car off, I couldn't find it. But I could turn the car on and off so I knew it was in there somewhere. I spent over an hour tearing it apart and looking in every nook at least 5 times. Even checked under the hood. I gave up and called to ask them where they put it. They told me to check the windshield - and there it was. Those A-holes actually left it on the windshield wipers. Said that is where they leave them sometimes. I explained what a stupid idea that was with a smart key. That $300 dollar key would have been gone if I cleaned the windshield or it started raining. I don't think they do it anymore.
#25 ·
#27 · (Edited)
I've been reading through this post, and have actually learned a bunch about my car! (2015 XLE) Thank you! I too would like the feature of having it idle while I walk out of sight. We have brutal summers in AZ, and when I have my dog in the car with me, I never stop anywhere, but, being able to keep the car and A/C running makes it possible for me to make quick stops.
