I installed the Magnaflow 19494 on my 2018 SE yesterday. For those of you that are considering it, but believed it only works on an XSE, don’t hesitate. It works and I have the parts list to make things easy.
Everything on the passenger side is straight forward. The system utilizes the factory hangers. The drivers side becomes easy when you order the factory hangers from Toyota. Both, the front and rear hangers go into the stock locations. The bolts are already in the vehicle. You just remove the black plastic shield that goes under the spare area and covers the place where the exhaust is going to exit on the drivers side. You can then back out the two bolts on each of the two (front and rear) muffler hangers and install them. The studs for the drivers side heat shield are also in place. You will have to purchase two nuts (I would recommend removing one from the passenger side heat shield and matching it up) .
The parts you will need are as follows. The cost will be around $100 for everything, plus shipping. I bought them directly from McgeorgeToyota.com. They had the best price I could find. It was cheaper to buy them from them, than Ebay. All are a quantity of 1 each.
