Myth Busting SeaFoam and Why it is a Ripoff
2 reading
30K views 11 replies 10 participants last post by  thomascarson2687
So it is normally around $12 a pint.
Rick's Free Auto Repair Advice
Repair Topics > Fuel, Fuel pump, Fuel delivery > Should I Seafoam my engine
How to Seafoam my engine
Don’t
Every day auto forum members ask the same question: “Should I Seafoam my engine?” If you want to use Seafoam to clean fuel injectors, my answer is no. There are much better products to use in my opinion.
What is Seafoam engine treatment
Seafoam is one brand of engine treatment. The manufacturer lists three ways it can be used; poured into the crankcase to remove crankcase deposits, poured into the gas tank as a fuel injector cleaner, or sucked into a vacuum line as an upper engine or top engine cleaner. According to Seafoam engine treatement’s MSDS product safety sheet, it’s comprised of three liquids;
Pale Oil 40-60%
Naphtha 25-35%
Isopropyl Alcohol 10-20%
So you’re looking at a product that contains a lubricating oil, a solvent, and alcohol. All three products can act to break up engine deposits. That’s what it claims to do. So far, so good.
Seafoam engine treatment as an engine cleaner
If you add Seafoam to your oil, it can dissolve buildup and deposits in your crankcase. Sounds good, right? Well, towards the end of this article I discuss the pros and cons of using an oil additive to do that.
Seafoam engine treatment added to your gas tank as a fuel injector cleaner
The two most effective fuel injector and fuel system cleaners are polyisbutylamine (PIBA) and polyetheramine (PEA). Seafoam doesn’t contain either of them. The Naphtha and alcohol components can act as solvents to clean deposits from fuel injectors, but I believe they’re not the best cleaners for fuel injectors or carbon deposits. I’m not sure how the Pale Oil helps clean fuel injectors, but keep in mind that Seafoam engine treatment claims that their product can be used in multiple ways, so as a fuel additive, perhaps the Pale Oil rides along for free and burns like ordinary fuel.
Seafoam engine treatment injected into a vacuum line to perform top end cleaning
When added to the gas tank, Seafoam engine treatment is applied to the back of the valves by the fuel injectors (in non-direct injection vehicles). But when used in a vacuum line, Seafoam engine treatment comes into direct contact with all the internal components located in the intake manifold. So the solvents have the potential to contact and clean valve stems as well as the back of each intake valve. Again, not the best cleaners, but they do clean.
Now let’s compare the chemical makeup of Seafoam and other products that claim to clean fuel injectors. I’ve picked some popular brands
The first two products on the list are multi-purpose cleaners Seafoam engine treatment and Gumout Multi-System Tune Up. You’ll see that they’re also oils, Naphtha, and alcohol
Sea Foam Motor Treatment SF-16, SF-128, SF-55 (Sold in bottles at retail stores)
MSDS contents of seafoam
Seafoam MSDS
Gumout Multi-System Tune-Up (Sold in bottles at retail stores)
Gumout Multi-System Tune-Up MSDS
Next we have products that are marketed specifically as fuel system cleaning products
Chevron Techron Fuel Injector Cleaner (Sold in bottles at retail stores)
Chevron Techron fuel injector cleaner
Chevron Techron Fuel Injector Cleaner MSDS
Chevron Techron Concentrate Plus (SC) (Sold in bottles at retail stores)
Chevron Techron Concentrate plus
Techron Concentrate Plus (SC) MSDS
Chevron TECHRON Bulk Gasoline Additive (added as a fuel injector cleaner at bulk storage sites)
Techron additive
Chevron TECHRON Bulk Gasoline Additive MSDS
Gumout All-In-One® Complete Fuel System Cleaner (Sold in bottles at retail stores)
Gumout fuel system cleaner
Gumout All in One complete fuel system cleaner MSDS
Lucas Deep Clean™ Fuel System Cleaner (Sold in bottles at retail stores)
Lucas deep clean fuel system cleaner
Lucas Deep Clean™ Fuel System Cleaner MSDS
Royal Purple Max-Clean Fuel System Cleaner & Stabilizer (Sold in bottles at retail stores)
Royal Purple Max clean
Max-Clean Fuel System Cleaner & Stabilizer MSDS
STA-BIL fuel stabilizer (Sold in bottles at retail stores)
sta-bil fuel stabilizer
STA-BIL fuel stabilizer MSDS
ACDelco Upper Engine and Fuel Injector Cleaner (Sold in bottles at GM dealers and online)
ACDelco upper engine cleaner
ACDelco Upper Engine and Fuel Injector Cleaner MSDS
As you can see, each product has a different chemical mix, ranging from distilled petroleum products to polyether amines (PEA) and glycol ethers and aryl alcohol. As you go from a general multipurpose cleaner like Seafoam and Gumout Multi System tune up, you’ll see the ingredients change from light oils and Naphtha to PEA, glycol ethers, trimethylbenzene and proprietary products. Keeping in mind that all Top Tier fuels require fuel injector cleaners, it’s worth reviewing the Chevron Techron bulk product that’s added at the fuel depot prior to deliver to the gas station.
Back to Should you seafoam your engine?
In my opinion Seafoam or similar products added to a tank of gas won’t hurt your engine, although I’m also not convinced that the light oils and Naphtha based products do much good. I think if you’re going to add a gas treatment to the tank, a product containing polyisbutylamine (PIBA) and polyetheramine (PEA) might perform better.
Next comes the issue of whether you should inject Seafoam or other top engine cleaners like the ACDelco Upper Engine and Fuel Injector Cleaner cleaner into a vacuum line. Here’s where I have a problem with the technique.
In a vehicle equipped with a MAF sensor, all incoming air is metered by the MAF usually mounted right after the air filter. As soon as you remove a vacuum line on a MAF equipped engine, you introduce UNMETERED air. The PCM sees the unmetered air by way of the pre-cat oxygen sensor suddenly going lean. The PCM responds by adding fuel. Now you inject Seafoam or Gumout Multi-Tune product into the intake vacuum line along with the added fuel. Whether you’re cleaning the valve stems and interior of the intake is almost irrelevant at this point because what you’re also doing is dumping extra fuel and cleaning solvents into the catalytic converter. What’s a catalytic converter? It’s an incinerator that’s designed to burn off excess fuel and oil. If the catalytic converter on your car is mounted in or right after the exhaust manifold, this injection technique can cause your catalytic converter to overheat and self destruct. Yup–a $1,000 repair bill because you tried to clean your engine.
So what can you do?
First, you can try another injection method. The ACDelco Upper Engine and Fuel Injector Cleaner product recommends injection by atomizing the product into the air intake duct, not a vacuum line. That way you’re not getting unmetered air past the MAF. To do this you can buy the product in an aerosol can or buy an atomizer canister. Load the liquid into it and pressure with compressed air. Then, spray the product into the air snorkel so it’s measured along with incoming air. As the product burns, the pre-cat oxygen sensor notices the richer mixture and the PCM cuts fuel trims. In my opinion, this is the only safe way to inject a top engine cleaner without destroying your catalytic converter. However, some car makers still warn against this method. They’re concerned that however much the PCM cuts back on fuel trim, this additional fuel may be too much for an exhaust mounted catalytic converter to handle.
For top engine cleaning, I prefer the ACDelco Upper Engine and Fuel Injector Cleaner atomized into the air duct prior to the MAF sensor.
Finally, there’s the issue of using engine flush solvents in the crankcase.
I have to honest, I’m not a fan of this at all. My opinion, of course, but if you take care of your engine with regular oil changes, you don’t need to add any solvents or flushing agents. I believe they do more harm than good. When poured into the crankcase as an additive, they tend to loosen deposits that can break away and clog oil galleries, hydraulic lifters, and the oil filter. So you think you’re doing your engine a favor and the next thing you know, you’ve got a lifter tick or engine knock. Instead, I would opt for more frequent oil changes if you’re at all concerned about deposits or sludge in your engine.
©, 2015 Rick Muscoplat
Find this article useful? Share it!
Posted on July 11, 2015 by Rick Muscoplat
eautorepair.net
eautorepair.net
Get the BEST auto repair information
Alldatadiy.com and Eautorepair.net are professional-grade shop manuals—period. They include wiring diagrams and technical service bulletins. In most cases, their diagrams are right from the factory manuals.
Pricing:
---Eautorepair.net---
1 month subscription $19.95 per vehicle
1-year subscription $29.95 per vehicle
4-year subscription $44.95 per vehicle
---Alldatadiy.com---
1-year $29.95 subscription: additional vehicles $19/95 each
5-year $49.95 subscription: additional vehicles $34.95 each
Which one should YOU choose?
If you’re tracking down a wiring issue, Eautorepair.net is the better choice. Eautorepair.net redraws factory wiring diagrams in color and includes the component, splice and ground locations right in their diagrams. That saves a lot of time because you don’t have to refer back to the component locator or circuit locations. Alldatadiy.com, on the other hand, uses the factory diagrams. So you have to refer to the factory legends to learn the identification symbols and then refer back to circuit diagrams to find the splice and ground locations.
However, Alldatadiy.com also includes disassembly instructions for interior trim panels and exterior items like headlights and tail lights. If you need to dig into your doors, dash or console, Alldatadiy.com is the better choice because Eautorepair.net doesn’t any interior or exterior trim or body part removal.
Anyone that tells you Seafoam will clean the fuel system added to the tank of a car or will clean up a dirty engine especialy on with piston and rings that are gummed up is either ignorant of science, chemistry and how tribology in situ works in a car or they are liar. You can be a FANTASTIC Automotive Technician but be an idiot when it comes to chemistry and tribology! When I was a kid Mom's the world over cleaned food of the faces of children with some spit on a napkin but I would not call "Mom Spit" a good cleaner! LOL
You know what Seafoam is great for? Old Motor Boat Engines and producing huge clouds of smoke behind your car!
You can either be a good NPC consumer and waste money on junk or you can use science to pick the right chemistry for the job at hand! The only thing worse than getting no real world results outside placebo is getting no real world results and paying top dollar for that!
Now we will have to set back and wait as 10,000 consumers pipe up with how it did wonders for them with no before and after photo's, no UOA, noting. We call that confirmation bias, placebo, cognitive dissonance, ignorance.
The ingredients in the can when used as directed can not produce the desired effect that is a scientific fact. In terms of de-carboning if your not afraid of hydro- locking an engine you could use water in a bottle as we did when I was a teenager.
Seafoam works great as a gas stabilizer. It also did a great job improving the idle on my Jeep 2.5l with 250,000 miles.
I put it any tank that will be sitting for a long period, such as winter. Never had a problem.
I would never use its an engine cleaner. That’s what oil changes are for.
It’s a great product and I will continue to use it.
Rick's Free Auto Repair Advice's Free Auto Repair Advice
Don’t
Pale Oil 40-60%
Naphtha 25-35%
Seafoam MSDS
Techron additive
So what can you do?
eautorepair.net
eautorepair.net
Pricing:
Yeah, good read, thanks. Don't use it myself either. Slick 50 anyone? How bout some liquid luster(easy on, easy off). Ahh, if only a transmission rebuild came in a can.
Cheers
A catalytic converter is not an "incinerator" and it is most certainly not designed to "burn off excess fuel and oil."
It's function is to convert poisonous carbon monoxide (CO) in the exhaust flow to carbon dioxide (CO2).
That is a part, and only a part, of its function.
How Catalytic Converters Work | HowStuffWorks
And the stage that deals with hydrocarbons and VOCs is, for all practical intents and purposes, an incinerator. From the above noted article:
The oxidation catalyst is the second stage of the catalytic converter. It reduces the unburned hydrocarbons and carbon monoxide by burning (oxidizing) them over a platinum and palladium catalyst. This catalyst aids the reaction of the CO and hydrocarbons with the remaining oxygen in the exhaust gas.
One of the reasons you don't want misfires or anything causing a significant amount of unburnt fuel in a system with a catalytic converter is because of how dangerously hot they will become when dealing with excessive amounts of unburnt fuel.
I've used Seafoam in the past via the "open a vacuum line and spray in the whole can" while the engine is running. The throttle was wedged to run the engine at 2500 rpm or so. Solved the issue I had. The engine was a JDM motor that sat for who knows how long before I installed it in the car. Suspected that the rings had glued themselves to the ring lands in the pistons from sitting so long, as the engine ran great but smoked some. The Seafoam treatment stopped the smoking and the compression came up some. No issues since. Car has no catalytic converter, so no need to worry about that.
For regular fuel system treatments though, I usually just put a bottle of Amsoil Performance Improver in the gas tank once or twice a year.
On my fleet, there's only been once when I put in some Techron as an injector cleaner; I had picked up my new-to-me '99 Camry and thought, what the heck. Otherwise no gas treatments, just gas and go.
Maybe Seafoam does something on engines that are carboned up, just not sure I'd want to mess with on something that isn't having problems--I can't imagine that running oil through the engine is good for the catalytic convertor. In low concentrations it wouldn't do much to the cat, but then... is it doing much of anything at that point?
I have to think, just getting out on the highway on a regular basis and running it hard, at least once in a while, probably does the most to keeping things clean. Puttering around town probably does the most damage, and even then... it's not the 1960's.
Reactions: guyslp
#9 ·
I use it in fuel. Me and my dad have for years no issues. I’ve had some fun with it in cars too we put some in my buddies bronco and man that thing smoked so badly the nursing home next to the shop called the fire department because they thought there was a fire 😂. That’s when we put it in the engine.
Good Post, however one thing I would like to correct you on is this, whenever you suck seafoam up into a vacume line you are NOT introducing unmetered air, simply because you are not introducing hardly if any air at all actually (if done correctly) i have been doing it over 15 years with good results, also i agree seafoam in the tank is a waste. Anyway old post but a good one 👍
