New oil change interval?
1 reading
1.9K views 6 replies 5 participants last post by  Doneaccordingly
Is this guy crazy or he knows something? Manual says 10000 miles, I can understand 5000, but 3-4000. Something fundamentally wrong with engine if it require 3000 miles oil change. Or for turbo should be used different type of oil
Sooner on Turbo applications, stock or modified. If you don't then expect early bearing or shaft issues.
If you want to extend it to 5 maybe 6k under normal conditions then use Amsoil Signature, it preformed better in Turbo Coking Tests.
Its what I use in my 1JZ with external oil cooler.
