Hmmmm I will check on that tomorrow then. I may have at one point threw a 10 amp fuse in there years ago to replace a previously blown 15 amp fuse, I'd rather blow a fuse by putting a lower amp fuse in rather then putting a higher amp fuse in and causing worse damage. The only thing that doesn't make sense about that is when i checked the continuity on the bulb sockets, they weren't reading as open circuits. Wouldn't a blown fuse not complete the circuit. I hope this fixes it; however, it will be kind of embarrassing considering I have almost had everything else apart for such a simple fix.
I got sidetracked earlier because i think i blew one of my HID ballasts when i was troubleshooting the switch socket connections. I had to replace a fuse under the hood, checked the ballast there, checked the switch again. Only to try it with an older ballast i had and find out that it was a ballast that was blown. I guess this is what happens when an amateur messes around with things.
