'04 Sienna LE
I have searched this problem and I have not been able to find a solution.
The left side, front of the van will control the temperature correctly, the right side is always cold.
I removed the glove box and the kick panels on both sides of the center console.
The motor that activates the blend door moves correctly when the temperature is moved from cold to hot and hot to cold. I removed the motor and activated the blend door manually and there is no change in the problem. Left side temperature is adjusted when moving the door but no change to the right side temperature.
I thought maybe there was another blend door in the left side, but there is only the motor that controls the position of the air flow (floor, vents, defrost) and that is working correctly.
Am I missing something?
Any ideas what the problem may be?
